Item: SXC Custom NSW number plates
Item Condition: Excellent
Reason for selling: Sold car, no longer needed
Price: $350 or will swap for something of interest (plus cash adjustment if necessary), laptop, LCD TV etc
Payment Method: Pickup - Cash, COD
Extra Info: yellow plates, black text
Edited by weaponx
https://www.sau.com.au/forums/topic/160668-sxc-custom-nsw-number-plates/
  • 3 weeks later...
this would be an awesome addition to a SX model dude .. are you posting on Nissan silvia.com?
I think its abit over the top for skyline owners .. would imagine some with these plates would have an inflated ego?! lol
Yeap ill post.. doing it now m8
http://www.nissansilvia.com/forums/index.p...howtopic=233625
please let me know ur contact number so I can post it also .. So everyone dont PM me
Edited by DECIM8
  • 4 weeks later...
  • 1 month later...
