Hi
Has anyone dropped in a Toyota JZ engine into a ceffy? What is involved with it?
I'm thinking about replacing my rb20 with a 1jz TT from a soarer as it is long in the tooth now.
I know a lot of guys have done the conversion with s13's.
1JZ's seem to be pretty cheap comapred to a SR20 or RB25/26
https://www.sau.com.au/forums/topic/160742-jz-ceffy/
1jz is cheap and better than 25
but the 25 conversion is much easier , which realy is one of the main advantages of the cef , its ready for any rb very easily
having said that its not that hard and the 1j is an awesome engine . the soarer turbo setup sucks though
Edited by arkon
https://www.sau.com.au/forums/topic/160742-jz-ceffy/#findComment-2986052
what you save on purchasing the Jz will spend and more on the conversion
talk to some mechanics on the cost of converting first
remember that although the SR or RB maybe a 500-1000 more expensive to buy, it is a straight fit
im thinking to shoehorn a toyota engine in a nissan is a few grand enterprise
Food for thought
RellikZephyr
https://www.sau.com.au/forums/topic/160742-jz-ceffy/#findComment-2986054
there is a guy in SA you can buy mounts off for $120 which allow a direct bolt in for a 1JZ onto an S13 X member, Ceffy X members are worth a shiteload more cash than S13 ones, so you can probably get your $120 back on that with no worries :rofl:
once that is done its a bit of wiring and some plumbing (as you would need with any conversion) and youre set...the only real expensive bits I can see are $1500 for an R154 (but you pay nearly that for an RB25 box which is weaker anyway)
I was seriously going to do this with a GT3037S Pro into my laurel if i didnt sell it.
https://www.sau.com.au/forums/topic/160742-jz-ceffy/#findComment-2987155
what about the opposite side exhaust/inlet etc?
https://www.sau.com.au/forums/topic/160742-jz-ceffy/#findComment-2987332
what about it?
the inlet is no dramas whatsoever...as for the exhaust well a 1JZ has the dumps in the centre of the engine leaving you PLENTY of room for a decent front pipe and exhaust, if youre going a big single there shouldnt be any dramas either :P
https://www.sau.com.au/forums/topic/160742-jz-ceffy/#findComment-2988427
Here's my 1JZ powered Cefiro... don't have a lot of information about dropping the JZ into a Ceffie, since mine was already installed when I bought the car. I do know that here in Thailand people can buy looms off the shelf to splice into the standard loom and then everything plugs straight in, no drama!
https://www.sau.com.au/forums/topic/160742-jz-ceffy/#findComment-2988544
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
