I know the gtr ones are bigger than gtst ones so are these the bigger size axle ,I thought the gts4 axles would've been the same size as the gtst?
Yep these are the stronger 31spline 6x1 bolt axles.
The GTS4 drive line is pretty much identical to that of the GTR apart from the diff ratio being slightly lower at 4.375:1 vs the gtr's 4.11 to help the poor ol' rb20 lug that 1550kg's around. :huh:
Unsure if gearbox ratio's differ.
Do correct me if I'm wrong though. A mates GTS4 follows this suit and its also what I've been told by a couple of wreckers.
I priced up the gtr axles a little while back. I remember the average price wanted was $175 each axle so 300 total. I will double check tomorrow just to be sure I'm selling these for a reasonable price.
I have a Z31 centre and have fitted a LSD 1.5 way R32 Centre. I just now need to find half shafts and axles to fit it all. My current axles are only like 28 or 29 teeth on the spline and are not long enough. Would it be the "R32 GTR GTS4 31spline 6bolt Axles" or the other items you are selling that would best suit my needs?
Actually, looking at it, I think i need the input shafts you have for sale and also the axles.
$200 + postage for all items?
Would be to Green Point on the Central Coast, NSW.
Cheers,
Mike
Edited by Regina
The 31spline half shafts I have are to suit a VLSD center. So the usual one long, one short half shaft.
I've been told (but never tried) that you can use 2 of the shorter half shafts from a vlsd center in a mechanical center. You would have to confirm.
The axles.. well they are just regular 6bolt 31spline axles. :kiss: $150 + postage for those. I had them for $200 + postage but dropped the price.
Unsure if the half shafts are suitable, you'll have to price up what you can get another half shaft for 'IF' it is possible that you can use the shorter half shaft from the 2 that I have.
Let me know if you are still interested and in what. I'll package the items up and grab a quote for postage.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
    • Yeah, I would have said the same. It makes me suggest that there are other things wrong, such that the ECU is totally unhappy with the broken sensor. The only other thought here is that maybe it is shorted, which might cause a different issue to the typical "disconnected" sensor.
