Hey guys, clearing out some bits left over from my 2 R33's
Set of stalks - Wipers/Headlights (GTR ones without fog light or rear wiper knobs) - $BEST OFFER
Boost Controller, the tap style one listed on these forums in that massive thread - $SOLD
RB26 AFM (From R33 GTR) - SOLD
Stock Turbo Back Exhaust(S2 GTS25T) Includes turbo heat shield but no cat - $GONE
High Brake Light - LED, used in compliance at top of rear windscreen - SOLD
Child Restraint brackets and clips - $10
Redline lightweight shockproof box oil left over 2-300ml $10
Stickers 1x Buddy club, 2x Red Line, 1x Unique Auto Sports - $10 the lot SOLD
All prices are excluding postage and pics can be arranged if required, I assume most of you know what this stuff looks like but if you insist I'll bust out the digicam. Open to offers for any of it and happy to consider trades for similar priced items or offer me something cool or a total $$ and take it all, so yeah open to whatever - trader feedback shows I'm not gonna scam u guys.
Cheers
Dan
Edited by ActionDan
https://www.sau.com.au/forums/topic/161477-r33-gtst-and-gtr-bits/
  • 3 weeks later...
  • 3 weeks later...
  • 1 month later...
Redline Oil and Child restraints were throw out during the move. Stalks and AFM will go on eBay unless someone wants them for a cheap price. The exhaust is free to anyone who wants to come get it :D
I also have 2 Skyline owners manuals (just the ones you get from the import yard) and 2 SAU VIC stickers if anyone is interested.
Cheers
    • You Gregged a whole racetrack!?
    • Look for broken wire or bad connector at the motor. Might not be it, but is worth starting there, as it is easy.
    • Hi everyone, I’m having an issue with my R32 GT-R. Sometimes, when the car goes over a bump or experiences some vibration, the 4WD warning light comes on the dashboard. When I check the code from the control unit in the trunk, it shows Code 19 – ETS Motor. However, everything seems to be working fine — if I turn off the engine and restart the car, the light goes away and everything functions normally. Has anyone experienced this before? Where should I start troubleshooting this issue? Thanks in advance!
    • I'm back from the dyno - again! I went looking for someone who knew LS's and had a roller dyno, to see how it shaped up compared to everything else and confirm the powerband really is peaking where Mr Mamo says it should. TLDR: The dyno result I got this time definitely had the shape of how it feels on the road and finally 'makes sense'. Also we had a bit more time to play with timing on the dyno, it turns out the common practice in LS is to lower the timing around peak torque and restore it to max after. So given a car was on the dyno and mostly dialled in already, it was time for tweaking. Luis at APS is definitely knowledgable when it came to this and had overlays ready to go and was happy to share. If you map out your cylinder airmass you start seeing graphs that look a LOT like the engine's torque curve. The good thing also is if you map out your timing curve when you're avoiding knock... this curve very much looks like the inverse of the airmass curve. The result? Well it's another 10.7kw/14hp kw from where I drove it in at. Pretty much everywhere, too. As to how much this car actually makes in Hub Dyno numbers, American Dyno numbers, or Mainline dyno numbers, I say I don't know and it's gone up ~25kw since I started tinkering lol. It IS interesting how the shorter ratio gears I have aren't scaled right on this dyno - 6840RPM is 199KMH, not 175KMH. I have also seen other printouts here with cars with less mods at much higher "kmh" for their RPM due Commodores having 3.45's or longer (!) rear diff ratios maxing out 4th gear which is the 1:1 gear on the T56. Does this matter? No, not really. The real answer is go to the strip and see what it traps, but: I guess I should have gone last Sunday...
    • 310mm rotors will be avilable from Australia, Japan, and probably a few other places. Nothing for the front can be put on the back.
