heyy im looking for an r34 to import and i know that the R34 GT is the non turbo and the GTT is the turbo but what the hell is a R34 GT TB or a R34 GTT TB....
i keep seeing it but i have no idea what the TB is?
any ideas?
cheers
https://www.sau.com.au/forums/topic/162638-r34-gt-tb/
yeah i was thinking that but i was looking on j-spec and they had a r34 gtt tb as well as r34 gt tb???hrmmm
if anyone could help me solve this little mistory i would be much appreciative :)
cheers
https://www.sau.com.au/forums/topic/162638-r34-gt-tb/#findComment-3020738
