Got a few things for sale.
1. Custom 3" Catback Exhaust with Magnaflow Muffler to suit R32 GTST. (Has no flange on Cat end). Sounds very nice on an RB20. $200
Im located in the northern suburbs of melbourne. If you need to contact me, just PM me or SMS me on 0413397069.
Mike.
https://www.sau.com.au/forums/topic/162665-custom-3-exhaust-cheap/
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
