Haha, I'm REALLY jealous of a car that keeps breaking down! :D
And being more noticable isn't always a good thing either.
And mitchy, what crawled up your ass and died? Just because I don't like you doesn't mean you need to troll all my posts. :/
Back on topic, too bad this years ignition cruise was over before it even started. :no: The last one was the shizzle.
your car died at the same time, i just fixed mine myself. :)
people notice my car, and you get all bitchy that they didnt notice your car (stockish looking white 33.. get a more common import why dont you)... "my car was first, blah blah blah"
seriously carl, get the f**k over yourself, nobody gives a flying f**k if your car was first, or that you seem to not like me for whatever reason it is now..
ps. my name isnt stageagirl, i didnt reply to your posts. ;)
