ok ive been hearing this noise coming from my front left suspension area for the last couple of weeks. when ever i turn my stearing wheel or go over speed bumps or pot holes it makes like a tyre tread rubbing on a plastic guard/Springy noise. it hard to explain but it kind of sounds liek a worn out mattres spring. im going to hopefully get it check out on friday, but i was just wondering what u guys think it might be just so i could get some prices ranges on fixing it.
some suggested to me that it was my suspension bushes.. does this sound correct?
thanks in advance
https://www.sau.com.au/forums/topic/164180-suspension-problem/
it does have after market springs... but its not overly low... i can clear square curbs..
do u hear the noise all the time or just when u turn? maybe your tyre rubbing against the inside might need spacers or some thing, thats what im thinking but really should get checked out.
it also could not be your suspension could be your power steering also making the noise maybe those rubber bushes need to be changed.
that your looking at $300 a each one by a mechanic not too sure about price, but i think it actually is your tyre rubbing againts the guard might need wheel alignment or spacers
Edited by BRUNSKIGTST
yeh dnt think its my tyre cause i only hear it when i am turning... but i wil turn the wheels and see if my tyres clear alright.. i hope its not expensive to fix.. :closedeyes:
best thing to do, if it isn't your tyre rubbing , take it to a mechanic and have the power steering checked out. Might need new Bushes, so then he will tell you the price also, and if you need spacers he will tel you how much too.
have a check of ur upper control arm bushes, sounds like it could be them.
if it is them, for polyurethane replacements itll cost about $140 for the bushes itself and about $180 to get them installed. the adjustable to change ur camber on the other hand which would be a better option since ur car is lowered i think goes for about $300 for the bushes not sure about install mite be more and add a wheel alignment to it aswell
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
