Hi all
Im woundering what could be causing my AF-2 on my PFC to read at only 0.03 volts?
We took the intake system appart to install an ID3 and on putting it back together it no longer works. Yes we checked it was plugged in. And we also pulled another GTR 32 AFM off another car and plugged that in, no difference.
Car wont rev, obviously and is running hugely rich.
What could be causing it?
https://www.sau.com.au/forums/topic/164875-airflow-meters/
your going to need to apply power to the afm off the vehicle and measure the output voltage on the signal terminal and check if thats working. (will find pinout on these forums somewhere) if its works then the problem is the ecu or wiring to the airflow meter plug.
https://www.sau.com.au/forums/topic/164875-airflow-meters/#findComment-3055891
"copied from the tread"
Yeah its not to difficult.
All you need is a 12 volt power supply, a fan and a multimetter.
Hook the power supply positive to pin 5 and the negative to pin 3.
Now hook the multimeter positive lead to pin 2 and the ground lead to pin 4.
You should once power is put the the afm see a voltage of around 0.5volts with no air flow.
Now turn on the fan and see if the voltage increases to around 2.5 volts.
This could be more or less depending on how much air the fan will blow.
A variable speed fan is best as it allows you to test the afm at different levels of air flow (more air more voltage).
The pin out of the afm is the same as the RB20 unit so if you get confused have a look at http://rb20det.com/air_flow_meter_pinout.html
Hope this helps champ
https://www.sau.com.au/forums/topic/164875-airflow-meters/#findComment-3069485
    • Not sure the US can import anything other than the C34 Stagea's, but if you can and you need to to tow, DO NOT under any circumstances get an M35 Stagea. If it is just as a family car and your country/state allows it, absolutely and definitely get an M35 (3.5L if possible as it is effectively a 350Z) over a C34.
    • Punch your VIN (nm35-xxxxxx) into Amayama.com You can see everything there quite easily.
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
