hey guys
im a little stuck as to what FMIC i should fit on my 32 gts-t
i have mate that can install the FMIC on so labour cost wont be
a big deal.
Should i look for a second hand or aftermarket R32 gtr FMIC
and fit that or should i go for a greddy trust V spec cooler supplied
and fitted for $800.
im only looking for anything around 200rwkw so im just wondering if
im cuttin corners goin for the gtr one and loosing performance compared
to the greddy V spec OR will the greddy cooler be a waste of money reason
being that its designed for alot more power than 200rwkw.
cheers guys...
Edited by RB32
https://www.sau.com.au/forums/topic/165261-need-an-opinion/
dont really want to start conflict but if its the 300 just jap ones ppl
have told me 2 stay away so now thats always in the back of my head
even though great results have come out from them.
with the 34 sidemount is that considered as an easy fit and also what would the price
be for the cooler and pipes.
in regards to the greddy vspec would that be just overkill for the power im after??
cheers
https://www.sau.com.au/forums/topic/165261-need-an-opinion/#findComment-3061359
yeh i was talkin bout the just jap or crd ones, i havent heard anything bad other than bad installation techniques.
I use one of Just Jap's Cooling-Pro kits on my R32 GTS-T - Fitted up perfectly and has been great so far and its been on the car for 8 months.
RB32: As a rule of thumb, don't listen to everything you hear :nyaanyaa:
https://www.sau.com.au/forums/topic/165261-need-an-opinion/#findComment-3061627
there pricey at around 1200 A kit check out auto barn where abouts do you live>? narre warrens a good autobarn
hmm fair i might have a look.
im also waiting on my mate to see if he can hook me
up with any piping for the gtr fmic.
thanx anyway guys..
https://www.sau.com.au/forums/topic/165261-need-an-opinion/#findComment-3066284
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
    • I got adjustable after market rear camber arm to replace the stock one's because got sick of having to buy new rear tyres every few months. Can anyone please let me know what the best adjustment length would be. I don't have the old ones anymore to get measurements. I'm guessing the stock measurement minus a few mm would do it. Please any help on replacing them would be fantastic I've watched the YouTube clips but no-one talks about how long to set the camber arm to.
    • Heh. I copied the link to the video direct, instead of the thread I mentioned. But the video is the main value content anyway. Otherwise, yes, in Europe, surely you'd be expected to buy local. Being whichever flavour of Michelin, Continental or Pirelli suits your usage model.
