Well i missed out on tickets, and only know 1 or 2 other people going and they wont take me! f**kers
your only chance was to win tickets, couldnt buy them anywhere...... its on this weekend aparently at a secret location! alot more rumors floating around but unsure whats true and whats not...
Any lucky bastard on here score tickets?
www.smirnoffexperience.com.au
any one wana take me :domokun:
https://www.sau.com.au/forums/topic/165754-smirnoff-experience/
i just want to see armand, he pretty much led me down the house music path years and years ago....
Wana take me along albert? ill ruv u rong time :D
some hottie babe asked me already, so cant really dog her..
sorrry man..
yeah armand live! wooo should be hectic!
ohh bros before hoes!
ouch!
hopefully i can score some on ebay or something!
Haha sounds like you need a large front bar to get someone to invite you. Hopefully tickets on ebay won't be as pricey as they are for all other house events
