Car: 1995 r33 gtst. series 1.5
kms: 111,000
Trans: Manual
Price: $14,500
Condition: Excellent
Details: Hey guys, i got this car 3 years ago and basically looking for a more sedate car. Got a good Mspec Kit, Sunroof, Series 2 rear Wing, Pod Filter, Turbo Timer, Exhaust and a Aftermarket CD. Everything is in good condition and it goes really well. Never been boosted, it doesnt have adjustable boost, it has been set on approx 7lbs (whatever stock is) since i got and assumingly, previously. The car is about as close to stock as you will find and has been the most reliable daily driver i've ever had. fully serviced and fully functioning. If anyone is interested leave a sms on the number listed below, post a reply, or send a pm. Cheers, Grim.
phone: 0448719056
if you need pictures follow link to
http://www.skylinesaustralia.com/forums/in...=122682&hl=
https://www.sau.com.au/forums/topic/166504-r33-gtst-for-sale/
    • New CAS just turned up from NZ Wiring. Looks like a nice bit of gear.  So, yeah. Triggered, bro. Realised I may as well do the cam belt while mucking about with it so will order one of them.
