Guest RedLineGTR
i sure you cant like connect them together they work seperatly. but i would prop just save up and get the powerfc with the boost controller, more stealth so pricks done rip the avcr out of the car, unless you hide it. Yah So more stealth, but also depends how it works out money wise, check the prices of the parts and see if its worth it. If you havent done much reaserch, call up some prices and check some web sites for some prices.
https://www.sau.com.au/forums/topic/16700-apexi-power-fc/#findComment-343173
Guest RedLineGTR
Originally posted by rb26dett
i'm running power fc and avc-r in my car. was told that the power fc's boost controller does not control boost as well as the avc-r.
and yes i think they do their things separately.
Might be true but they use the same boost solenoid so i dont see how it if would differ, anoyone wanna shed some light on the issue?? anyways from just looking at the units, the avcr has more seperate and cool features.
https://www.sau.com.au/forums/topic/16700-apexi-power-fc/#findComment-343237
yeah i need more light shed on this subject as im in same decision
avcr or bc for pfc?
https://www.sau.com.au/forums/topic/16700-apexi-power-fc/#findComment-343284
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
    • I'm interested,do you still have it?
