  • Replies 45
wow.. i never realized Rollaz were so popular amongst the masses :rolleyes:
'oath they are. They're kick ass little cars.
The silver AE82 hatch in my pics outruns a R33 GTST.. and it's N/A with almost no mods!
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
