2002 Subaru WRX
300kws at 24psi with 98ron
???kws at 30psi with C16 + Nos
Previous owner has done an
11.63 @117mph car now make 70-80kws more at same boost levels
Engine
• Stage 3 Trp race engine has done 6200km
• O ringed 2.5ltr sleaved close deck block
• Ceramic coated pistons
• Nitro treated bearings & cranks
• Heads are deck & O ringed
• Copper head caskets
• 14mm Head studs
• Custom Cams
• Custom Extractors
Turbo
• T60-1 ceramic twin ball bearing
• Turbo with K&N air filter
• 3" ceramic coated down pipe
• 2.5" ceramic coated up pipe
• 38mm external waste gate
• Blitz electronic boost controller
• 3" stainless steel exhaust with cannon
• ECU micro tech LT8's with 3 bar map
• Sensor & hand controller
Accessories
• Polished alloy front mount intercooler & pipes
• Polished over flow bottle & catch can
• Engine plastic ceramic coated red
• 125hp wet nos kit with purge kit – Zex brand
Fuel System
• Adjustable Malpassi regulator
• 800hp external Bosch fuel pump
• 2Ltr surge tank
• 850 Injectors
Drive Train
• Sti 6 speed Oz spec
• Custom TRP race clutch
Body & Paint
• Jetspeed body kit
• 2 pac purple engine bay
• Wingless boot lid
• Clear blinkers
• Sti lights
• Carbon fibre bonnet with 03 bonnet scoop
• M3 style carbon fibre mirrors
Suspension
• Adjustable coil overs all round
• 18 x 7.5 gold forged Ray's wheels
• 2 piece DBA 5000 rotors
• Freddo racing brake pads
Interior
• Tan leather
• Carbon fibre Sti door inserts
• JVC Dvd player and screen
Everything has been done for you
Some pic
Price: $45,000
Edited by mattj255
https://www.sau.com.au/forums/topic/168157-fs-2002-wrx-300kws-new-pics-page-2/
  • Replies 41
so wats this thing like on petrol, and wats it like driving on the street??
If you just drive it normal its good on petrol....if you drive it hard it gets thirsty :)
Driving on the street its just like other cars....just faster :rolleyes:
No. the buyer didnt have the money
Hi Matt,
as i mentioned on rexnet, a buyer with a zero rating thats been registered on ebay for less than a week ISNT a genuine buyer. You should only accept bids from people that have phoned you or some other requirement to somewhat satisfy you of their intended genuineness. Not 100% fool proof but pretty good.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
