hi. ive recently split with my partner and need a change. im currently earning about 45k working fulltime as an engineer in a hotel, but want to do something different.
anything really, but with similar or better pay. my current position has no room to move up through the company, so i need to move. Any industry but preferably not on the tools anymore, but i am used to being flat out everyday so i wouldnt mind at all depending on the work. I really would like to get a less physical kind of job tho and see where i can take it. maybe entry level but with room to grow quickly.
i have plumbing, carpentry, electrical, plastering, painting, interior design, lighting design, tiling, cabling etc etc skills. i build hotel rooms basically, as well as caring for the plant equipment etc. for a large sydney city hotel (300+ rooms, 2 restauraunts).
i have previous experience in window retrofitting with Sydney Windows, was a bike assembler, designed and built racks for an electroplating firm and a few otehr things. whatever i try i can do. Customer service is a given, i meet a lot of guests in the hotel and they are always pissed off when i enter and happy when i leave, as i can fix anything quickly while having a good conversation.
i was also a qualified pool lifeguard. i think my resus has expired but i still have bronze medallion and first aid.
also have uni-level chemistry, biology, engineering and mathematics education (3rd year arts/sciences, first year engineering) but quit for financial reasons, the plan was for me to work while my partner was at uni and then swap, but i guess that wont be happening now so im stuck working
any help is greatly appreciated. i realise i have few qualifications but i have a lot of experience in a lot of areas. i am a fun young man, who is happy to work hard. wish me luck.
https://www.sau.com.au/forums/topic/168716-wanted-new-job/
what holden? if you mean the fairmont in the pic, its gone about 2 years ago. i really dont know what i want to do so it makes it hard to look. i'll just keep checking everywhere i guess. how much do you get for help desk/call centre work?
im in glenfield, near ctown/liverpool but working in the city now anyway i'm used to travelling.
https://www.sau.com.au/forums/topic/168716-wanted-new-job/#findComment-3119903
    • Did this end up working? Did you take some pictures?
    • And finally, the front lower mount. It was doubly weird. Firstly, the lower mount is held in with a bracket that has 3 bolts (it also acts as the steering lock stop), and then a nut on the shock lower mount itself. So, remove the 3x 14mm head bolts , then the 17mm nut that holds the shock in. From there, you can't actually remove the shock from the lower mount bolt (took me a while to work that out....) Sadly I don't have a pic of the other side, but the swaybar mounts to the same bolt that holds the shock in. You need to push that swaybar mount/bolt back so the shock can be pulled out past the lower control arm.  In this pic you can see the bolt partly pushed back, but it had to go further than that to release the shock. Once the shock is out, putting the new one in is "reverse of disassembly". Put the top of the shock through at least one hole and put a nut on loosely to hold it in place. Put the lower end in place and push the swaybar mount / shock bolt back in place, then loosely attach the other 2 top nuts. Bolt the bracket back in place with the 14mm head bolts and finally put the nut onto the lower bolt. Done....you have new suspension on your v37!
    • And now to the front.  No pics of the 3 nuts holding the front struts on, they are easy to spot. Undo 2 and leave the closest one on loosely. Underneath we have to deal with the wiring again, but this time its worse because the plug is behind the guard liner. You'll have to decide how much of the guard liner to remove, I undid the lower liner's top, inside and lower clips, but didn't pull it full off the guard. Same issue undoing the plug as at the rear, you need to firmly push the release clip from below while equally firmly gripping the plug body and pulling it out of  the socket. I used my fancy electrical disconnect pliers to get in there There is also one clip for the wiring, unlike at the rear I could not get behind it so just had to lever it up and out.....not in great condition to re-use in future.
    • Onto the rear lower shock mount. It's worth starting with a decent degrease to remove 10+ years of road grime, and perhaps also spray a penetrating oil on the shock lower nut. Don't forget to include the shock wiring and plug in the clean.... Deal with the wiring first; you need to release 2 clips where the wiring goes into the bracket (use long nose pliers behind the bracket to compress the clip so you can reuse it), and the rubber mount slides out, then release the plug.  I found it very hard to unplug, from underneath you can compress the tab with a screwdriver or similar, and gently but firmly pull the plug out of the socket (regular pliers may help but don't put too much pressure on the plastic. The lower mount is straightforward, 17mm nut and you can pull the shock out. As I wasn't putting a standard shock back in, I gave the car side wiring socket a generous gob of dialectric grease to keep crap out in the future. Putting the new shock in is straightforward, feed it into at least 1 of the bolt holes at the top and reach around to put a nut on it to hold it up. Then put on the other 2 top nuts loosely and put the shock onto the lower mounting bolt (you may need to lift the hub a little if the new shock is shorter). Tighten the lower nut and 3 upper nuts and you are done. In my case the BC Racing shocks came assembled for the fronts, but the rears needed to re-use the factory strut tops. For that you need spring compressors to take the pressure off the top nut (they are compressed enough when the spring can move between the top and bottom spring seats. Then a 17mm ring spanner to undo the nut while using an 8mm open spanner to stop the shaft turning (or, if you are really lucky you might get it off with a rattle gun).
    • You will now be able to lift the parcel shelf trim enough to get to the shock cover bolts; if you need to full remove the parcel shelf trim for some reason you also remove the escutcheons around the rear seat release and you will have to unplug the high stop light wiring from the boot. Next up is removal of the bracket; 6 nuts and a bolt Good news, you've finally got to the strut top! Remove the dust cover and the 3 shock mount nuts (perhaps leave 1 on lightly for now....) Same on the other side, but easier now you've done it all before
