Misc Parts From R32 Half Cut And Odd Pieces... Pm Me What U Need
dont suppose you have an rb20det ecu by any chance, do you?
*fingers crossed*
hey mate sorry i dont. its on the S13.. at the moment.. fine me a PFC and ill sell it.
Pm sent
replied. all pms replied.
Bonnet sold
dash is off, and will seperate airvents... :mrt:
  • Replies 57
  • 1 month later...
Hey mark will see you tommorrow but was wondering if you have the vent that sits in the very top iof the dash for the demister on the R32 gtst.
i really need one i snapped mine when i painted my dash.
cheers kingy
  • 4 weeks later...
how much do u want for the dash dude? is it in good condition. i dont want any air vents or anything just the dash pad
make an offer.. itsin very good condition.. air vents are seperated. send me a PM
oi DELETE SOME PM'S your inbox is FULL
yo. sorry it fills every second week.. pretty small limit lol.
  • 4 weeks later...
still have all the under dash aircon gear?
hi richard
sorry mate goneski to adam a while back :)
anything else u need. got std a/c climate control unit the electronic one
hi richard
what you asking for it? cause i get error -26 on my climate control now, but its like my 3rd one, could be buggered.
hence why i thought it was the control box under the dash?
  • 3 weeks later...
any chance of helping us out again?
After the front crash bar off the R32 halfcut, if it is undamaged?
aircon compressor, still got it?
if so has it been sealed up as to not dry it out?
how much?
    • Ha, I've never pressed the X in all these years incase it removed the notification for all Admins
    • I don't know, I've never done it that way, but 1. While it is an interference engine, there is still clearance between the valves and the piston at all points in the regular timing cycle 2. There is not a lot of distance before you can't catch the top of the valve stem any more I don't know if 2 is greater or less than 1. But 3. If it doesn't work out you are f**ked, engine is coming out to disassemble so it is a big bet.
    • Semi slicks are horrible for road use, just use a high performance road tyre unless you really need the maximum grip. Noisy, unpredictable (amazing, until they are not), expensive due to very high wear and not good in cold and particular wet. And yes, it is a thing to store cars on stands instead of tyres if you know they are going to be parked up long term.....but who ever realises that a short park is going to stretch into years before it is out again!
    • I know in Australia you'll definitely get above 30c. Parked in the shade in Summer you'll be above that. 😛 But in cooler climates, you might get that warm driving on the highway for a bit, but you'd never get to full heat temp. I'll try and find some of my historical tyre temps between Aus summer and winter (be aware immin the warmer area of Aus too.)
    • I get that taking off the head is best but that's a bit much for "just" valve seals. I was just under the impression that one would be able to rotate to TDC and be able to temporarily drop the valve without losing it and effectively having to remove the head to then recover it. I never knew people actually pushed rope into the cylinder to do valve seals hahaha So just to confirm, just going to TDC will not work? In that case I know when I do valve seals I'll maybe just remove the head and do some other things while I'm there, or just wait until I do an engine build.
