Hi i am after a rb26 block standard if possible or a r33 short motor
Thanks
Matt
Matt if you cant find a 26block Benno still has his 25 short motor with parts, might be worth giving him a bell as i think he was after about $500ish for it :)
Whats the ETA on the GTR?
Ben
https://www.sau.com.au/forums/topic/168936-wtb-rb26-block/#findComment-3129886
hey mate i have 2.. i have an rb25det complete engine but will seperate the head from the block but there is damage to the waterpump bracket...$150
i also have a rb25de bottom end but i might want the oil pump off it
$200
both are in good mechanical condition..
here is a link for pics
http://www.skylinesaustralia.com/forums/in...howtopic=164775
i am located in melbourne and will send if need be.. cheers leigh.
https://www.sau.com.au/forums/topic/168936-wtb-rb26-block/#findComment-3153493
i have one asking $2500 needs a bearing (conrod)its complete , like the head still on the bottom end im in melb , sump been taken off for inspection , crank not too bad doesnt need much attention pm me or call tommorow on 0418 170 234
https://www.sau.com.au/forums/topic/168936-wtb-rb26-block/#findComment-3154099
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
    • Staring on a stand is no issue. You just have to wire everything up, give it fuel and cross your fingers that the stand is robust enough. Arranging the inlet plumbing is often the hardest part, without any surrounding structure to hand some of it from. No need for coolant if you only want to run it for <1 minute. As to the gearbox - I think the little Aisin box is a bit stronger than the other small Nissan boxes that went behind SRs, but I wouldn't be too keen to test its limits with the torque of a boosted 25. I don't know if you can retain the box and the tailshaft. The box won't connect to the RB without an adapter of some sort, which is either a plate that will push the engine forward (which is not good for fitting it into the bay's available space) or push the box back, which messes with the box position and tailshaft length - OR - cut and shut work on the bellhousing, which is a long way from "least modification". I'd be buying a new 370Z 6 speed or similar, doing what has to be done to that to make it fit RB (ie, cut and shut bellhousing) and the requisite tailshaft custom/mods.
    • Hi Everyone I am from West Pennant Hills in NSW. Been too busy until recently to attend to my RB25DET Series 2 engine until recently. I am planning to stick it into the S15 shell at this stage, unless a nice SR20DET turns up... For now, i am going to try and get the RB25 running and working well then decide what gearbox to use. My preference is to retain the SR20DET  6 speed gearbox and tail shaft to retain as much and least modifications as i can avoid. I am an old guy and won't be doing any heavy drifting so i don't need a bullet proof gearbox Does anyone have experience with starting the RB on a stand? I got everything setup as much as I can with the info i can find... endless searching and videos on Youtube I would be great to get some pointers Cheers Songo
    • Hey all, Recently have had my s1 r33 gtr serviced and noticed my coolant reservoir was topped up to the max line. Took the car out for 1 yesterday and noticed today the reservoir is completely empty.  Any ideas? Radiator is full
