To dig up a thread.
No issues with overboosting :( 15.5psi smack on perfectly the actuator appears to be a tad lazy but its apparently a common trait with the Garrett actuator.
I went with Shauns advice and stuck with a bell mouth to prevent boost creep. It has done the trick nicely.
BUT boost drop up top sucks. Its definitely blowing the gate open.
Time to get rid of the small diaphragm Garrett 1bar actuator and in with a large diaphragm 18psi actuator.
No idea haven't priced one up yet. Expecting 100-200 or there abouts.
The actuators can be used on the gt35's with out problem.
Yes still running the std flapper with a bell mouth its the .82 rear.
Checking everything over I noticed I have to place a hell of a lot of preload ~9mm on the actuator to get it over the wastegate flaps stud.
Hmm I never checked over mine that closely. Something that has been bothering me is a strange habit my car has - the wastegate opens at ~11psi no matter what. Boost will build sharply until it reaches 11psi, then it acts like the flap has cracked open slightly then boost will build until it reaches the preset amount I am after.
An electronic or manual boost controller does not seem to fix this - it only affects what happens afterwards. If I wind up any more preload on the actuator to alleviate this, it will boost creep past 15psi - it kind of puts me in a rock or a hard place. I will have a proper look at how everything is lined up tomorrow, perhaps I am getting the same thing but my car may be more subject to boost creep.
Its the crap 1bar actuator. Mine lifts off the seat hard at 11psi also. The ebc does help some what though as we have it not allowing any boost to the actuator until around 13psi. It seems to get it past the hump; much less and it will be crapo as you are experiencing.
The difference is huge. Without the ebc 1bar at 4300rpmish. with ~11psi at 3000rpm. Shove the ebc on it and it will make 1 bar at 2800rpm; usually on the street I see 19psi by ~3k.
Nice. With the AVCR I cannot use 100% duty, and it always creeps open - it effectively makes it take its time to 1bar and is really annoying. It gets to 11psi fairly acceptably and does climb a crapload faster than without the AVCR on, but still. Would an HKS actuator or something like that help, maybe?
what you need to do is think about the final boost setting you wish to run at.
dont waste your time having a low boost setting and a high boost setting thats just silly.
pick your desired final boost level say 20 psi, and then get a new actuator as close as you can get to that level.
ie a 18 psi actuator.
once you have that make the shaft to suit the position thats its in so the rod is pulling central on the diaphram and set about half a hole prelaod on the gate pivot.
then you will have good, stable, boost control.
the main benifit i found is boost will ramp up real hard to 18 psi before the gate cracks open so the midrange is improved dramatically.
and by using just half to 3/4 a hole prelaod you will get max travel from the flapper and therfore have good wastgate flow up high in the revs.
I know, and that is exactly what I did. I want to run 1-1.1bar (completely stock internal RB25) and in theory its a ~1bar actuator but it lazily creeps open before it reaches 1bar, hence the problem.
Edited by Lithium
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
