Hey all,
As topic states, ive got a 32mm Weber DCOE Sidedraft Carburettor for sale, in as new condition only a few weeks use, and i need it gone!
If you needs pics ive got more or if you need any info ask!
Asking $350
I dont expect anyone from here to need it but if you know someone please let them know!
Located in Melb, post is cool too.
Thanks!
Mat.
https://www.sau.com.au/forums/topic/169127-sidedraft-weber-dcoe32-carburettor/
what capacity motor is this carb suited to.... what was it in?
This will suit from about a 1600 to a worked 2L, it was previously on a gemini.
It would also be perfect for a L20 (datsun), ive also got a new manifold to suit as well if interested.
  • 3 months later...
will this fit a ra60 21r-c
Hey there,
It will 'fit', but youll need a manifold for it to fit your engine, which should be readily available i would think.
But this carby would be perfect for your engine in terms of size. Its a 2.0 correct?
Just PM me if youre interested.
    • Let large companies that are making money off selling kits do the preliminary engineering for you. If they all do -10, then that is all you'll ever need.
    • Hopefully it ends up being something manageable, like a hone, rather than a full bore—it would be a huge relief if it’s not as bad as it looks. Hang in there; these setbacks are annoying, but it sounds like you’re handling it as smartly as possible.
    • At the end of the day, it’s all about understanding the odds and being comfortable with the potential cost, whether it’s horsepower on a build or chips on a roulette table. And I have to say, the Laine example made me laugh—some people really do embrace that carefree, “roll and see” attitude!
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
