The stereo has been in the car a while now, and all of a sudden I have noticed that there is a sound dropout. It happens every now and then and is beginning to piss me off. I will start the car, and it sounds as if there is only sound coming from the rear speakers. It may take 5 minutes or half an hour and eventually the system goes back to normal.
The system comprises of components in the front and 6 x 9's in the rear run by an Audison amp, and two subs in the boot run by a cadence amp. I had pretty much the same system in the old skyline and I have disconnected and reconnected cables but to no avail.
Any ideas anyone?
https://www.sau.com.au/forums/topic/170428-sound-dropout/
i'd back the amps matie .. whatever is powering your front splits is having issues ... orrrr I know its a weird idea but your cones have dust one them .. check!! sounds weird but can seriously stop ur doof going doof .. has to be only about 1mm thick
also check your head unit .. see if wiggling the wires which connect to the h.u turns on the speakers.. then u might find ur problem
Edited by DECIM8
https://www.sau.com.au/forums/topic/170428-sound-dropout/#findComment-3148880
didnt you say in the first post that you disconnected and reconnected the cables?
well that includes earth cables... so if you have already done that, then i would suggest no... again...
but if you haven't done that, i would suggest going over your wires... again... for the first time...
is it a sudden pop and theyre working again? cause if it is, its a wire somewhere... or whatever amp is running them is going into protect when you turn the car on, then waiting to come out of it...
most likely cause of a LOOSE WIRE...
https://www.sau.com.au/forums/topic/170428-sound-dropout/#findComment-3149292
Dont get emotional. I did say I checked all the cables. Not the wires eg earth. Again... dont get emotional.
https://www.sau.com.au/forums/topic/170428-sound-dropout/#findComment-3149359
you make me cry :P
wires/cables... they're the same thing...
again... you make me cry :'(
Wires and cables being the same thing could be argued. Anyways, I'm only shit stirring hey. When I checked all the wiring/cables, I was referring to mainly RCA's and cables to the amps, speaker cables and head unit cables. As far as I can find there is an earth cable which runs from the head unit, and as the two amps are connected I think there is one earth from them.
As I never installed the system, I should probably just go to my installer but I was hoping to try and figure it out myself.
https://www.sau.com.au/forums/topic/170428-sound-dropout/#findComment-3149661
psh, your boot install is better... thats about it i think :woot: STILL haven't met you...
but yeah, its a weird problem... if it is just popping back on instantly, then its either a loose wire or the amp is in protect, cause of a loose wire... Wish i could have a look at it, but im betting its one of those... dont think its your gear...
that ground running from the head unit you speak of is the remote wire for the amps... it tells them to turn and off... its a constant positive feed, dont know how strong, but if its exposed somewhere and hitting the body of the car, then it will turn the amps on and off intermittenly...
DECIM8: Im thinking about dropping 2k on subs this weekend... you STILL gunna have a better system then me then? ;)
https://www.sau.com.au/forums/topic/170428-sound-dropout/#findComment-3150688
Hahah 2 K on subs .. wasting it .. I got my Fusion NV comp series for $300 and it shakes buildings apart... Not to mention my poor boot..
Wait im a lier .. Unless your dumping it on some JL series or somthing? Id love to hear that .. W7 :worship:
I hope you got some serious front setup to match .. I wanna install those crazy lil vibrating things... Haha just for the chiqs bro hahahah
My boot install is crap im going to rip it out and start again for the 3rd time .. to hard to please
I wanna see ur install!
https://www.sau.com.au/forums/topic/170428-sound-dropout/#findComment-3151130
Wait im a lier .. Unless your dumping it on some JL series or somthing? Id love to hear that .. W7 :yes:
My install is what we in the profession call... "temporary" :worship:
i have some powerful MBQ for front, and some alpine Type S for the rear... i still need to amp them, but they will be getting 100WRMS each when i get my ass around to doing it...
theres nothing special about my install as of yet, im still thinking up a decent and original design... i have a few ideas, but space appears to be the biggest problem...
and no, its not JL... the subs im getting are rated at nearly twice the power output of the 12W7... and its not some gimmick either...
see the 'danger zone'? thats the comfort zone for these subs :banana:
PS: they cost $1k each... but im getting 40% off... no one who is serious about this pays shelf price :3some:
https://www.sau.com.au/forums/topic/170428-sound-dropout/#findComment-3151227
yea thats right, if the fuse blows it wont turn on, i didn't say it was blown, when you test for condinuity on a FAULTY fuse, it has condinuity sometimes and sometimes its a broken circuit... i.e. his dropouts of sound
you must really love your bass to pop a fuse LOL
https://www.sau.com.au/forums/topic/170428-sound-dropout/#findComment-3151231
    • Yeah pretty impressive hey, good to see quality products not over-shooting their prices. That's what drew me to buy the hypergear turbo, just a shame I've never got the chance to see it in action
    • Thank you GTSBoy and MBS206 I have done the compression test with the motor out of the vehicle, reason for the test was to see if I needed to remove the head and do rings etc while its out. I'm in the process of respraying the vehicle and tidying up a few things. Story behind it all is I've just purchased the skyline and it was running when I got it, never drove it on the street though as I wanted to pull it down and do it all up again before registering it. the gentleman I purchased it from told me the motor has a forged bottom end and has a decent tune through it but I was going to pull the sump off anyway to see if it is a forged bottom end. that's why I thought id do a compression test beforehand.
    • Man, I'm kind of amazed that the price of the turbo has not changed in 7 years. Everything else is inflating beyond reason, but not this? Good on Tao / hypergear I guess? Anyways, good luck with the sale!
    • I'm selling my brand new, in the box, never used Hypergear ATR45 - and I had some additions I paid for a few yrs back when I purchased it. Never ended up having the rest of the money to add all the mods at once, so I just ended up slowly selling each part. I originally had it internally gated, with the dump pipe, however I found it was incompatible with what I was going to use it for, so I contacted (I think Ken) from Hypergear, and he and I messaged back and forth & he got me to ship the turbo back, where they modified it & made it externally gated, and gave me the 5 bolt dump pipe attachment for custom welding. (Photos below) This turbo like I said has never touched the inside of an engine bay, it's completely brand new, never used, been sitting in the same box it arrived in, covered in plastic & all. Below are the photos of it: And while the guys at Hypergear were making it in-shop, they sent me some photos of the process: I'm looking at selling this just because I'm in need of the money right now, and don't have plans on modifying the 34 anytime soon - and from reviews & peformance sheets, this turbo had amazing results back when I was researching. The turbo was purchased in 2018 for $1.9k, with the mods I got added on. Looking at the website now, for the same turbo they sell (ATR45SAT), with the current addons it adds up to $1830 for the turbo Current addons included: - Bolted dump adaptor - Ball bearing CHRA - Braided oil feeding line So I'm looking to possibly sell it for around $1800, with shipping included in that 1.8k, It cost me around $120 to ship - so yeah thought I'd throw it out there and see if anyone was interested in purchasing. Cheers!
