Hey all,
The guys in SAU-NSW have organised some awesome SAU gear. You can look at them at the following link...
http://www.skylinesaustralia.com/forums/in...howtopic=156571
There is everything from stubby holders to jackets... I've spoken to Goldzilla who is organising the sale, and have been told that we can get them here for an extra postage charge. I am trying to organise for all the postage to come to the same place and then distibute from there. This will mean that the postage is cheaper for everyone. I'm happy to organise this for everyone who is interested.
If you are interested, PM me with your details as well as Goldzilla. This way we can keep track of who wants what. I'm happy for all the stuff to come to my place and then distribute from there to keep prices down. As long as everyone is happy with that.
I won't be dealing with the money side of things and this is all going to the SAU-NSW account so just follow the details on the above link.
P.S. Dan, if I should do anything different, or get some one else, eg a mod, to organise, please let me know :/
https://www.sau.com.au/forums/topic/170500-sau-jackets/
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
