This thing still for sale, have u had it up here before or did i see it elsewhere :woot:
Really nice looking car,
*awaits leakdown/comp test results*
You can't sell with the rims originally pictured can you? not a fan of the BBS'
Edited by r32 gts-turbo
yeah sorry i didnt get stock rims with the car. yeah it was up for sale when the clutch needed a rebuild and i didnt want to fork out the money for it lol. but now its currently being done
Because i want my new car asap and the gtr market is sorta dead im willing to go to $20,500 minus the BBS rims (will be replaced with probaly r32 gtst rims). although at this price, i wont be throwing in the pfc & cam gears for free unless i get the full $22,500 :woot:
Well i do get pretty decent wheel/tyre deals so it shouldn't be a problem.
Was that cluster put in since you bought it or did it come from japan?
Also any stacks, and is it original paint?
i had to get another cluster cuz the stock cluster was reading 10km/h higher then what you were actually going. wen i got the car it was on 77,000km, was replaced at ~89,000km. tomei one was used and started at 104,000km. so yeah about 15,000km worth of me driving.
i hope to get the car back soon as i do have abit of interest arising. cheers!
paint is really good for its age, i had to get the rear right qtr panel repainted cuz some top bloke hit my car while they were trying to park. but other then that all good :woot:
    • Also seen this as an option
    • I get you, we’ll see I’m aiming for 200ish kw now and hopefully 300rwkw down the line after some upgrades maybe like headstuds, E85 flex fuel etc  so trying to make it final for that now, I can get a GTT airbox for $280 so it’s not too bad but not sure if there’s better ways to spend that money. I seen online they say pod filter which isn’t enclosed isn’t good especially for a plus T.      hard to say what to do
    • Meh. How much power can you make from a +T anyway? I wouldn't have though it would be enough to challenge the airbox. It's not as if it's tiny compared with the turbo one. As to putting a pod in a stock airbox .... it's not the filter element that would be restrictive. It would be the air inlet to the box that would be the narrow point, which you could open up regardless of what element was inside. On my R32 I opened up the sort of triangular opening in the bottom front corner of the box, deformed (heated, moulded) some 4" stormwater pipe to fit to that opening and punched a 4" hole down through the inner guard to the spot where the stock intercooler used to be. This was purely in the search for a cold intake, but you could do something similar if you need to open up the inlet side of it. The AFM tube size is the same for both NA and turbo, so the outlet from the airbox is same same anyway. If you're going to do the right thing, then an aftermarket ECU won't care about the AFM (ie, you can get rid of it). But even if it was still there, people pull >300rwkW through them all day, and I suspect you won't be going there.
    • R34 RB25de Neo by the way ^
    • Doing a +T on my car and I’ve read the precious forums lots of mixed reviews from sometime back.  checking if anyone has any ideas for airbox or enclosed pod filter or solutions?  I was thinking stock GTT box but some say it’s restrictive? I seen some people try fit in a pod in the box anyone done that recently?  not any good enclosed options ? Thanks
