hey everyone im in the market for an EBC and i was just wondering if anyone has had any experience with the hks EBC 6? i was ready to buy the 5 before i discovered the existence of this beast....
i was just wondering if there are any major differences between the two boost controllers? apart from price and the EBC 6 looking so much cooler! also im getting alot of people calling the EBC pictured the HKS EVC 5 aswell.....somewhat confused
Edited by killswitch88
https://www.sau.com.au/forums/topic/170753-hks-evc-6/
that evc you pictured is the 5 and is thier latest edition
Hks japan link.
http://www.hks-power.co.jp/products/electr...oost/5_evc.html
Translated link
http://translate.google.com/translate?u=ht...Flanguage_tools
then somewhere along the way.. i think some where around hawaii last year it suddenly became!
http://www.hksusa.com/products/?id=3208
dumb americans
Edited by Angus Smart
https://www.sau.com.au/forums/topic/170753-hks-evc-6/#findComment-3151673
theyre calling it the EVC 6 on the HKS USA website http://www.hksusa.com/products/?id=3208
thats just f*kd me even more
EDIT: should really have read the rest of your post first....then where does that the other one with the four buttons down the side of the screen.....4?
https://www.sau.com.au/forums/topic/170753-hks-evc-6/#findComment-3151684
Yeah thats 4. and also came in black limited editions.
i have that and itsnice and easy to use! i love it!
https://www.sau.com.au/forums/topic/170753-hks-evc-6/#findComment-3151753
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
