hey man, how close do you seriously think they'd go to sneaking under the guards of a 33 GTR? i love em, i want em, but i don't really want to start hacking away on the body of my car, it's in mint condition and i wanna leave it that way if i can help it
I think the fronts will fit ok, I think the rears might be stretching the friendship....altho having said that, here's an R33 GTR with 18x11s and it looks fine - obviously offset would be a little more conservative;
http://www.pistonheads.com/members/showcar.asp?carId=34480
passing this ad onto a friend, awesome wheels and even better price.
>> shipping will probably be $50+ per wheel. i got quoted 40 bux per wheel for 15x7" with no tyres from sydney so i imagine these will be more to brisbane and a bigger wheel.
Wheels are still here.
...to those who have PM'd me wanting freight prices I apologise, work has been nuts. I will get prices asap.
Hi Chris,
Let me know when you have a price(s) for shipping to Brisbane ;)
I am still very keen on these rims ;)
Also, a side note for those S13 people out there with 5 stud conversions.. you'll need approx 5" wider rear guards and 3" wider front guards to fit these :P
Regards,
Sherwin
...also, a side note for those S13 people out there with 5 stud conversions.. you'll need approx 5" wider rear guards and 3" wider front guards to fit these :bunny:
Regards,
Sherwin
I beg to differ young Sherwin...I test fitted them under the back of my old R32 4 door and I needed to pull the guards out 70mm to clear the rears. Bearing in mind 1 inch = 25.4mm, 70mm = 2.75 inches. In addition, an S13 has bigger rear guards & tubs than an R32 4 door and is also more dish 'friendly' - as it's a coupe and has the full quarter to play with (i.e. no rear doors).
You'll definitely need wide body or flares, but 5 inches is a bit extreme IMHO. Too bad I don't have my S13 anymore to test fit them.
Up ya get!
If they are still there in about a week or so then i'll pick them up.
If anything i'll need spacers to cover up my wheel arches i think i went a bit overboard with my widebody
:thumbsup:
Up ya get!
I used an offset calculator to got those dimensions.. but I was doing it with 3 different rims at the time so I may have them mixed up??
Either way, when you have a price for shipping to Brisbane, Pm me with the payment details :thumbsup:
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
