First owner since it arrived from japan
very clean inside and out
I havent had time on my hand as yet to do anything to this car,
it hasn't been thrashed, i go to uni everyday.
i rarely take the skyline out for a spin, so i gurantee u that this car is at a very high standard.
i have never red-line the car, and to be honest, i don't think i have even pass 5000rpm.
NOTHING IS WRONG MECHANICALLY WITH THIS CAR,
if i lie, the car will explode tomorrow!
It is a metalic silver car, TYPE M SPEC SERIES II GTS-T (TURBO) - nonsmoker driver.
Manual
Genuine 63.700 km's
Location = western sydney
Its pretty stock, BUT it has a:
Aftermarket sports exhaust, from the dump pipe (TURBO) to the cat-back
APEXI POWER FUNNEL pod filter
LIGHT UP KENWOOD REAR SPEAKERS (when headlights are turn on)! with 20 cd changer in the rear boot!
Aftermarket cd deck (pioneer) - very very loud and nice sounding system.
-AM/FM is in working order, attachment installed for attenna to go up and down.
CUSCO adjustable suspension - good heavy duty suspension.
It also comes with the ORIGINAL SKYLINE MATS! very very nice and clean!
New clutch was put in at the time of import. Not a stock clutch, nice deep and semi-heavy clutch.
Runs stock boost, with series 2 features! i,e, dual airbags etc..
Brake pads have been changed (120$), and air-con regased (90$)
To add, i have a MOONGOOSE 2 point immobiliser (the best only for the best!)
The paint work is in VERY MINT condition.
PRICE: 14,299 firm
Its price to selll!
the car is definitely worth the dime,
be quick to grab a bargain, before i change me mind.
REASON FOR SELLING:
My family just doesnt need another car in the house.. its only travelled 1000km in 4 months!!!
REGO till 28th feb next year!
dont give me stupid offers, im serious here, i'm not desperate.
if u come to see the car, 50 bux deposit first, then a test drive obviously price is aggreeed first!
Dont hesitate to call, the worst i can say is no. The name is David Mai
You may contact me on 0432 213 763
OR if u prefer, drop me an email [email protected]
Edited by davib
wat the hell, dave?! why u selling your car for? you had big plans for it :D
definitely have to see this car in the flesh guys - very straight, very clean, and well taken care of by an enthusiast.
goodluck with the sale dave, will be sad to see it go...
guys, will be posting some new photos later.
and thanks for coming down andrew, here from you soon
anyone else want to come and see the car, just gimme a call
but please, no time wasters and looking around.
thanks for the comment derek
in saying that, why are YOU selling yours!
hahahha goodluck with your sale man.
definitely beautiful cars.
no worries... the car deserves the compliments. man, there comes a time when you just need a change.
i still can't believe someone hasn't snatched this up yet though... great price for a really clean series II R33
someone BUY IT ALREADY!
deriq
yeah im suprised as well,
I can't believe its not gone yet!
but i guess we just have to advertise our cars on a wider presepective aye..
posted another picture hahaha
mrHele, u got a pm!
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
