has it been engineered? and is it currently regtistered with the 186?
Currently registered with 186/4 speed and had no trouble with Special Interest rego prior to obtaining full rego.
All paperwork reflects correct engine number for 186 for AIS inspection and full Tasmania registration :banana:
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
