Hello all
I have the following items for sale
4 x s13/ a31 stock wheels 15 inch by 6 alloys with tyres + a spare with brand new retread- $199 neg
8k JIC s13 springs from coilovers - $40
Stock a31 rear swaybar - with endlinks - $free
R33 5 stud front hubs $50 for the pair
Full set of 16 Black Rays light weight lock nuts for sale. with key. Used condition. Some black anodising has chipped off
pics soon - $SOLD
Bov block off plate - $SOLD
4 stud work meister S1 wheels, front - 17 x 8 +30 offset and rear 17 x 9 +35 offset.
Black with polished lip
they will come with tyres about 50% tread on tyres
reason - i have gone 5 stud. SOLD SOLD SOLD
pics below SOLD
s13 /a31 front Whiteline swaybar with U bushes, and endlinks (no bolts) - SOLD
z32 / r32 front calipers (painted Black) includes pads and shims and all that stuff - $SOLD
Located in Sydney northside of harbour
Pick up preferred esp for the large items.
thanks
Alex
Will post pics tommorrow.
Edited by Resin
  • 3 weeks later...
i will be selling my 4 stud work meister S1 wheels soon
they are front - 17 x 8 +30 offset and rear 17 x 9 +35 offset.
they will come with tyres i will let you know condtion of those soon.
reason - i am going 5 stud
i think i will be looking for around $1950 pickup
Any chance of pics for the meister rims and the 15" stockies... also North Side.. (Chatswood) so could be keen on both or either!
  • 3 weeks later...
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
