Hello all, I will be ordering a shift kit on Monday, and have decided that I want to get a hi stall converter to go with it.
By the time I get my hands on one and get it put in, I am reasonably expecting something in the area of 180 – 190rwkws.
After having looked thru a bit of info about them, I understand that the procedure of picking a torque converter is related to where the engine is making peak torque in the rev range. Not having had my car on the dyno to see exactly where its making its peak torque does make it a little difficult to work out what stall speed I should be looking at for the converter. I notice that the majority of people on here have ones rated 2800 – 3000rpm.
Is it safe to simply pick one off the shelf, even though one rated at 3000rpm might not always be the best real world application? I have read that I should be looking at one that is rated at around 500rpm lower than where peak torque is generated. Using the 3000rpm example, would that be best coupled to an engine that is producing peak torque at 3500rpm?
My intention is once the car is dyno'd and I know where it's doing what, then I can work out what the converter should be rated at. The car is to remain completely drive able – I drive it 400klms a week – so I am obviously not gonna be chasing up something rated at 5500rpm lol.
I am basically looking out for any advice anyone can give about this. I would also like to know about other people's set ups. I have referred a fair bit to the auto power and ¼ times thread that I have found on here, but it mainly refers to numbers, not set up details.
Also, what is the best way of measuring this 'stall' – Flash or True stall? Not planning on having a transbrake, would I be correct that Flash stall would be what I should be asking about?
I appreciate any and all comments or advice anyone has to offer (this is the 1st auto 'performance' car I have owned, so I am like a sponge at the moment – I am soaking everything up lol)
Cheers,
Chris
Edited by sxc33
https://www.sau.com.au/forums/topic/173850-picking-the-right-stall-converter/
hey chap
r33 stall convertors are awesome little things.
they still lock up when not under heavy load while the old school chev / ford etc convertors wont.
im running the 2800 / 3000 rpm convertor in my 33 yet the car will happily go up hills at 1600 rpm in drive.
my old chev 3k high stall needed to be doing 2750rpm to move, let alone going up hills.
so in answer to your question contact mike at MV automatics over here in Adelaide and he will organise one for you.
the highest they can go with the stock convertor housing is the 2800 / 3000 rpm that i run, and this will be perfect for you.
if you want to go higher for some reason then you will have to get a smaller convertor 4 cylnder nissan i think, and then that can be modded up higher around the 4000rpm mark but the cost is 2.5 times more then the 2800 convertor.
i hope that makes sence.
hey chap
Cheers for that mate. Maybe a 3500 is not gonna happen, so a 3000 it prob will be.
My big concern was wether it would need a piss load of revs to just navigate over speed bumps or a slight incline etc.
Have u noticed any difference in fuel economy and what revs it needs to keep a steady 100klms even?
As i mentioned above, the high stall will still lock up and drive from around 1200 rpm and above like a standard convertor, its only when you load it up on the brakes or on a big hill that it will go up to stall speed of 3k etc.
normal driving you wont even know its there.
I highly recomend a 2800 from MV Auto's, and im running over 300 rwkws everyday in my wifes daily shopping bus
Cool. Was seriously worried about drivability of em eh, but i was gonna do it either way.
With regard to putting it in, did u do it yourself? I got a shift on my loungeroom floor that i am gonna put in, but i am thinking a stally is a job for the pros.
If your keen to install the shift kit then the High Stall is simple.
put your car on a hoist or up on stands, then unbolt the trans and drag it out.
un bolt the standard convertor off the engine, and bolt the new one on.
roll your trans on its back undo the pan and install the shift kit then bolt it back together.
with a dozen beers it shouldnt take more then 5 / 6 hours job done.
failing that just get a local trans place to do it for you.
prob around the $300 mark
Stally aint gonna happen for a month or so (fingers crossed i get a new job and get paid out a SH!T load of holiday pay). But i can access to a hoist anytime i want (the stage 2 kit is going on sat), so i am reckon i should give it a shot!
Cheers for all your info dude, much apprecitated!!!
Chris
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
