I have HKS coilovers in my car, but don't know the model, whether it is dampening adjustable, camber adj, whether it has poillow tops.
Where can i go to check which of these it does have, and what brand these are?
Also, can you "service" coilovers rather than sourcing new ones?
How much does this cost?
And it has these turning knobs above the rear parcel shelf. What the hell are these???
I only had springs in my old car...so new to coilovers.
Thanks!
https://www.sau.com.au/forums/topic/174503-how-to-check-coilovers/
Thanks!
usually dampening force is adjustable via turning pegs on the tops of coilovers. somethimes they are marked with lines and numbers. if you see something like this then they are probably adjustable for dampening force.
Thanks!
yeah... this knob u talkign about is ur damper adjustment. Click them all to zero (anti-clockwise) then click them all to say 10 and make sure they even or will ride like crap.
As for camber/pillowball tops. Camber tops are only available in Macpherson strut desings. Skyline does not have this (silvias do). You probably do however have pillowball tops (metal tops) Look under your bonnet at your coilovers.. or through the parcel shelf and there should be metal around that "knob" its probably purple/pink if its HKS. If you have this metal then congradulations u have pillowball tops. Realy only advantage of these are its a bit stiffer then the standard rubber/plastic tops.
Also if you jack your car up and take your wheel off and look at ur coilovers you will see a seat below the ring.. it is two seats holding the spring up. If you dont have any "C" Spanners then get a screwdriver and hammer and u can loosen them by turning them and adjust the height of the car. But make sure you clean all the threads befor you go doing this or they will seize up and get stuck.
As for servicing coilovers yes, yes you can have them serviced and it is approx $100-$150 each. Only do it if needed
cheers
Edited by choku_dori
bought my car prob 10 months ago and have always thought the coilovers are too loud....always wanted the to be checked out, can say pedders or beaurepairs look at them to check they are still safe?
always thinking im gonna loose a wheel or something....
Slight correction, pillowball tops are not refering to the strut top itself being metal, I havn't seen one that isn't metal yet...
If it referring to the fact that they use a spherical bearing/rose joint/pillow ball to locate the shock shaft to the strut top. For a street car, they provide lots of NVH and wear out quickly, then begin to knock once they start wearing out.
is it normal for coilovers to make clunking sounds from the rear?
like a shitbox with long gone suspension?
Cause mine clunks and rattles alot
Clunking sounds is a sign ur coilovers are way past its used by date. They are probably leaking. You can either get them reconditioned (https://www.shockreco.com) or buy new ones.
Reco is different to being serviced?
servicing = replacing struts, seals, regas etc... = rebuild. Costs around $150 per corner approximately from TSR in Brisbane.
$600 is cheaper than $1600+ so i guess i'll get them serviced
only if they guarantee no more clunking :P
does anyone know where car I get my Tein HR coilovers servicing or rebuild? i'm on the Coast NSW and dont have stock suspension ! do i need my car to put on stands when I do servicing or rebuild?
Cheers
I was talking to EastCoastSuspension.
And they said they can't service my coilovers (HKS) as it's imported...
Anyone know who can service HKS?
And as for u subie, i think fulcrum can service yours.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
