closest I can think of is hitman at Penrith mate
Yeah Hitman is a good one, next to race solutions in Penrith.
Go along Castlereagh rd, turn onto jack williams drive.
They are on Borec road, not sure of address # though, but in same complex as the hairdresser
I heard lots of good things about hitman. I never been there and I am pretty close (St Clair). I go to UNIQUE (Seven Hills), they fixed lots of my problems and as you guys saw at show'n'shine it pays.......
EUG
I was going to mention the Hitman but everyone beat me to it.
None that i know of in the actual BMountains so Hitman it is and he has a top reputation on SAU and with me.
He tuned mine on the Power FC.
Should be a sinch for the SAFC.
