  • Replies 453
Posted Images
my car is going in on sat to fix a problem with one of the wires in the pfc loom. causing massive headaches!!! short my car out, its really wierd. gotta get it put on dyno again, so put me down as a maybe cause i dunno if its gonna be finished.
DAMMMMMMMM!!!!!
bad luck.. hope it all works out well & we'll see you on Sunday.
I'm getting my car looked at today to try to fix my boost problem. Driving my mums corolla around... soooo much different around the corners :blink:
hope it checks out well.
I'm getting my car looked at today to try to fix my boost problem. Driving my mums corolla around... soooo much different around the corners :P
Yeh hows that boosting issue working out? Heard anything from the mech? It's odd you have two levels, maybe actuators or something.
alrite guys a final rev up for me coz wont be on again til sat arvo. massive big huge and ginormous are words that are describing this cruise atm.
i have spoken to the harbour master at apollo bay and got the all clear from him to have the cars on the pier to take photos. max 30 cars at a time tho just so photos are quick and not dragged out.
COULD EVERY1 ON THE LIST THAT IS UNDER MAYBE PLEASE POST WHETHER NOT NO THEY COMING. I WANT TO REMOVE THE MAYBE LIST AND JUST HAVE DEFINITES.
:P
Hey guyz anyone from the Eastern suburbs want to meet up and head to Avalon together i got one other skyline coming just wanting to see if anyone else is goin from the east.
P.s. Gettin my FMIC, dump pipe and high flow cat this sat cant wait to test it out on the cruise im pumped wish it was sat nite already.
PM me if ur out in the east and want to cruise in together
Cj
Cj
mate speak to dilmah or ashneel. they have a small meet happening at the stud park shopping centre. it will meet up with the mini meet at kmart and then as a whole we will head to the main meet point.
ok, looks like the following people are meeting at
The Warehouse in Stud Park Shopping Centre which is on Stud Road at 6.30am for a 7.00am sharp departure.
We will then travel (not via city link) as a group to the main official pre-meet at the Kmart in Campbellfield with enough time to have a bit of breakfast & chat with the rest of the guys:
What is your route going to be from stud park? If you could let us know where you will be crossing springy road, well join the pack there coming from the east...no point going backwards...and i dont like knox area...and what time do you think?
P.S count me in for definates plus 2.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
