the factory vct switches off at around 4500rpm so you get a bit of a flatspot there.
before anyone says that it is rich and retard, that is a violent on/off. and zennon gets it on his r32 and they don't have rich and retard as far as i know.
a new ecu won't fix the problem. it is to do with the variable cam timing. if you got an aftermarket ecu you could adjust where it switches on and off, but that would just move the problem, not get rid of it. if you didn't have the vct kick in at all you would just end up with it being less powerful at low rpm. about the only solution is aftermarket cams.
its hard to say - when i use to have a super lightweight flywheel it seemed to just loose it all together
now i have a normal lightweight flywheel and it seems to loose it and then come back
when the air is very dense (heavy) IE cold cold night - it seems to rev fine all the way to 7 without any problems...
would this indicate its an air flow problem?
for me it feels like it funs out of boost so it pulls then flattens out then after like 5000-6000 rpm it starts boosting hard again
i had the same issue all i did to fix it, is repair coilpacks, regap spark plugs and change my ecu to PFC which has seem to fix the problem i dont know which one has fix the problem as i did all this in one go lol. :worship: i have full boost and full power though out the rev range
    • Can't you put the pistons to TDC and then do the valve seals? Or will the drop down too far to pull them back up?
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
    • You have no idea how many goddamn boxes I received these past three months haha Most have been put to use by now though, luckily
    • Not going to pretend I didn't do a bit of junky work this time around, but mostly due to the fact that some things I am not willing to spend days fixing right now, like wiring. I try to do most things properly the first time around.
