i guess 110 on a tough dyno isnt too bad! he said it would read lower! he said fuel system is perfect! but i dont have many mods to really increase the power!!! so i guess it is stock coz u dont gain kw's from cooler and i have a zorst with stock cat!!! so i guess i would be ok?
https://www.sau.com.au/forums/topic/175577-110rwkw/page/2/#findComment-3219322
as above, but in different terms:
if the clutch is worn it means its slipping away some of the power being produced by the engine rather than transferring/clamping it to the driveshaft.
not sure what good a 'tough' dyno is (wouldn't an accurate one me more useful?), i'm assuming they mean the rollers are 'tougher' to turn. so if the clutch is a little worn, that extra resistance would make it harder for the clutch to clamp = slippage.
https://www.sau.com.au/forums/topic/175577-110rwkw/page/2/#findComment-3226910
    • R34DE as in R34 with an RB25DE? So did you get this? Or you planning to?  I'm not really sure what you're saying.
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
