hi guys
just wanted to know what the best ehaust will be for my GTt.
thanks
lee
Hey Lee,
Since your in W.A i would go see Dom from Prestige exhausts in Malaga bit of a drive for ya but worth every cent!!!!
I got a full stainless from turb back system cost $1550 fitted and it is a XFORCE exhaust with hiflow cat and so on hope that helps ya :nyaanyaa:
I have a HKS Silent Hi Power system going on my R34 GT-t with HKS front and dump pipe in a couple of weeks. I will tell you how it goes.
I wonder if the Silent part of the model name is a misnomer. I'll soon find out.
Hey Lee,
I got a full stainless from turb back system cost $1550 fitted and it is a XFORCE exhaust with hiflow cat and so on hope that helps ya :dry:
thanks. just checked out a couple of pictures looks good but what is going on with the end of it? its got something weird lookin in the end of it. how does it sound?
Is the Trust PE II any good?
And can i get a dump to suit the Nismo catback that my car has? (the one with EVC)
Unless of course the Nismo catback is crap for handling more power...
Edited by Fujiwara
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
