ive got r33 turbo, manifold and dump/front pipe...
ive got full cooler kit
anything ive missed out?
noone wants to buy my cefiro n/a so thought may aswell throw a cheap turbs setup on for the kiddies...
it will only be running 10psi or so... well i dont drive it but for the new owner it should be safe without HG
anything ive missed?
https://www.sau.com.au/forums/topic/176675-rb20det/
wondering how an rb20det a31 ecu is gonna go with the non turbo a31 afm... im kinda trying to do this on a budget
if i was keeping the car i wouldnt bother with this dicking around and id slam a 20det in... but eh... this is easier and cheaper
https://www.sau.com.au/forums/topic/176675-rb20det/#findComment-3230828
agred it is thats why i not doing the rb25de+t option in my post i doing transplant for rb25det, but yes you need:
Basic run down in price from what i estimate is
- Turbo 200
- Manifold 50
- injectors 100
- Dump 100
- Front pipe 100
- Intercooler 140
- Pipe kit 150
- Oil feed 120
- Emanage 300
- Randoms 100
i have a topic you can read about if you don't like.. http://www.boostcruising.com/forums/index....=209006&hl=
but the ones on SAU are probably better, i prefer them now
GL dude
https://www.sau.com.au/forums/topic/176675-rb20det/#findComment-3231032
You may have to lower compression ratio..
OR..
Go HI COMP TURBO! :) (SOMEONE DO IT ALREADY!)
I dont see why u cant use the A31 ecu.. it will run.. but it may not optimumly..
another thing.. you may need oil feed lines to the turbo from the block..
Id sigguest a retune too.. may need that one..
Have a feeling there is more.. but will dorp back by if i remeber..
https://www.sau.com.au/forums/topic/176675-rb20det/#findComment-3231103
dude, i have a cefiro de+T and i can tell you right now this isn't a "cheap" way to go
you need oil and water feed return lines, plumbing by enzed, DET injectors, colder spark plugs, DET cefiro ECU, cooler piping, new inlet cross pipe, dump, front pipe,
there's heaps you still need, how much are you looking at selling the cefiro for though? i may have an interested friend
seriously though if you're looking at increasing the value of the car then this is not the way to go man, you'll lose a lot of money!
https://www.sau.com.au/forums/topic/176675-rb20det/#findComment-3231162
    • Out of curiosity, how do you cover up the inspection hole? Surely it doesn't sit open like that, right? With grime and dirt coming in and oil going out?
    • Hi from Canada, Both of my calipers are starting to fail. My car is a 2005 M35 Stagea ARX and I can't seem to find any parts or any cross reference caliper that would fit my car. Is there a company or a similar caliper that would fit and I could replace the OEM one. Or if anyone knows where I can find a new OEM. Any help is very appreciated. Let me know!
    • Maf is a question mark but TPS  I have set at 0.47, the fact that I’m getting proper voltage range out of it with the key on leads me to believe it’s functioning properly. I’m getting proper voltages on basically everything. I still need to look up voltage ranges for z32 maf and test that
    • Honestly no not at all, but it’s a very basic tune, it’s stock injectors q45 tps and z32 maf. Other than that it’s a completely stock base map. The file is from nistune and from my understanding if it was tune related I would be able to unplug maf and tps and it would still start even if it was a really shitty start. I have tried starting it with coolant temp, maf, and tps unplugged none of those 3 togethor or individually changes anything
    • 🏆 Skyline Supremacy Meets Mount Panorama Magic 🏆 Join SAU NSW as we take the long way to Bathurst, the home of GTR greatness. Saturday 30th August 2025 7:00AM Meeting Hanna Park North Richmond 7:30AM Departure Cruise Via Bells of Line Road 9:00AM Arrival to Stop 1: Golden Poplars Meadow Flat 9:45AM Arrival to Final Destination: Mount Panorama Motor Racing Circuit Meet Location: Hanna Park North Richmond Stop 1: Golden Poplars Meadow Flat Final Destination: Mount Panorama Motor Racing Circuit   *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
