If you put a different hose running from your intercooler pipe to the actuator you are running more boost because there is less pressure going to the actuator so the wastegate doesn't open and keeps building boost. The standard vac line that runs to the actuator has a restrictor in it that reduces the diameter inside the hose. A smaller diameter means higher pressure - higher pressure means wastegate opens earlier creating less boost. Imagine it like having a pea shooter - with the thin pipe it will shoot quite far due to the greater pressure but if you had a large diameter pipe with a pea in it it wouldn't go very far. - hope that makes sense :)
That coupled with your new exhaust.
Dude that sounds so wrong.
the smaller pipe will not give you a higher pressure. are you saying that the air pressure in my intercooler piping could be say, 10psi, and because my piping to the actuator is smaller, the pressure inside here will be around 15psi? It doesnt work like that. use common sense.
In actual fact, because an actuator has little air flow to it, the restrictor wont do alot other then slow movement and proberbly make boosting smoother on the standard setup.
Where is everyone taking there actuator tap from? my problem has been fixed, i moved it to the piping immediatly after the turbo and fitted new BIGGER hose straight to the actuator.
It doesn't sound wrong at all Dude.... It is common sense. Reducing the diametre of a hose increases the pressure inside the hose. Hence why do you think taking the restrictor out of a gtr or an s15 for example ups the boost when replaced with a generic piece of fuel line or silicon hose... Because the pressure to the actuator is reduced hence the turbo creates more boost as the wastgate doesn't open as early or as much.
Cheers 'dude'
Btw 'slowing airflow to the actuator :huh: ' is not going to make boost come on 'smoother' If anything it would ramp up faster and harder because the wastegate is not opening as much.
Which is why that is Not what it is doing in the stock setup.
Edited by R33silverS2
Cheers 'dude'
Your analogy is completely wrong. As i said before.
You seem to not understand the relationship between pressure and flow. are you saying if i block off a pipe, and plug the other end into a compresser, that as the pipe gets smaller and smaller it will have higher pressure until it reachs the end? You cannot deny the fact that when flow ceases pressure will equalise on both sides of a restriction. For this reason, I don't see how having a smaller pipe will give you less boost.
can anyone else clarify? perhaps with some more in depth arguements?
LMAO
Because the pipe going to my boost gauge is really small, MAYBE, just MAYBE i am reading a much higher boost then i am actually running.
DEAR GOD
the problem is solved, maybe we have different boost gauge piping!
what size is the pipe running to your boost gauge R33silverS2? :huh:
Your boost gauge is calibrated to run off a certain diameter hose. Go plug in a bigger one than it came with and see how you go....
Also please give us your expert analysis on why boost increases when the restrictor hose is removed... >_<
Also enlighten us to what the brass restrictor is for...
LMAO
DEAR GOD
what size is the pipe running to your boost gauge R33silverS2? >_<
>_<
  • 3 weeks later...
Also please give us your expert analysis on why boost increases when the restrictor hose is removed... :laugh:
heres what I've figured so far.
Ive been talking to some pneumatic gurus at work and you are WRONG. smaller diameter in the pipe does NOT mean there is greater pressure. in actual fact, the pressure remains very much the same. Flow only increases. Because of this, and we all know the restrictor lowers boost, the guys believe that the restrictor is in place to keep the gate open longer, after pressure is removed from the actuator side. This means that the wastegate, once fully opened, takes a while to close again, meaning that the boost pressure is kept lower. There is NO such thing as a restrictor to increase pressure, it simply holds pressure at the diaphram for longer. (unlike what R33silverS2 has stated several times, pressure does not increase as the pipe gets smaller)
I fitted a restrictor to my car last week (went and bout 2 inchs of copper tube that fitted my vaccum hose) and my boost has dropped to around 8 pound consistently. The restrictor does work. Obviously, the most efficient way to control boost is electronically. Because of the restrictor, the wastegate also takes longer to open and this means it would be easier to have 'boost spiking' present.
Hope this clears a few things up.
    • They're all horrible. X-Trails have had a nasty sounding 4cyl since forever, no matter what engine family it came from. The CVTs only made that worse. Then the whole Renault thing only made every Nissan that was contaminated by them even worse again. The only fun I've had in a X-Trail was having it blown sideways across a frozen Minnesota highway at 90 mph trying to make it to the airport to get out of the frozen hellhole of Hoth. Nearly died. Was great fun.
    • Alrighty, I'll have to grab a couple pics and type out something soon in another post. I haven't driven a modern X no, this would be the first one really. Yeah the rental boxes are always cheap as chips right? So I'd doubt that anyone was handing out GTs to go and abuse. But I s'pose I could be wrong for sure. New cars these days though? Pretty unimpressed with what I see now; 20 years and all that, like you said. It just kind of worked out to have these two cars now. I'm pretty pleased with that, don't need much else. I'm sure you lads are right about the temps and for sure, you wouldn't have much time to drive 'em down there if you all were like me. I do hate sweating all over the seats though😆
    • Let large companies that are making money off selling kits do the preliminary engineering for you. If they all do -10, then that is all you'll ever need.
    • Hopefully it ends up being something manageable, like a hone, rather than a full bore—it would be a huge relief if it’s not as bad as it looks. Hang in there; these setbacks are annoying, but it sounds like you’re handling it as smartly as possible.
    • At the end of the day, it’s all about understanding the odds and being comfortable with the potential cost, whether it’s horsepower on a build or chips on a roulette table. And I have to say, the Laine example made me laugh—some people really do embrace that carefree, “roll and see” attitude!
