Brand New D2r Hid Globes, Direct Drop-in For R34's With Factory Hid, 2 X 6000k And 1 X 8000k
As the title says, these are brand new drop-in replacements for those highly expensive HID D2R factory globes.
Can be replaced in minutes, I've got
2 x 6000K sets (very white)
1 x 8000K set (slight blue hue) SOLD
$75 for a set (2 globes) delivered express throughout Australia.
Hey Dan, how do these compare with the stock HID's? (The 6000k ones)
And would it match the color of your LED's?
Edited by Fujiwara
They're very close in colour to the LEDs actually, I always think (being fussy) the stock HID are slightly less blue than the LEDs. This could be due to age of my factory ones though. Also the new bulbs have a slight colour shif after 500 hours and get a bit white-bluer.
Got decent white (but not noticeably illegal) replacements for halogens? Bastards at compliance never returned my Xenons...
Sorry no halogens, only HID
whats the kelvin rating on the stock HID's?
And can the wiring/loom handle 8000k
8000K refers to the colour temperature, they don't use any more current load than the stock globes, these are 35W just the same.
I've heard figures of 4200-4700K for stock...I'm tending toward the 4700K
i got 2 sets of dan awsome xennon bulbs .. huge diff over stock 4200k xennons.. thanks a bunch bud for them :banana: well worth the money
P.S my fatory booklet states mine was a 4200K maybe the earlier ones were different??.. 8000K is worth it :yes:
Edited by 53XYN
does the 8000k still light up as much or more as the standard ones?
I haven't done the 6000K side by side with the 8000K, but it was brighter than the stock ones, just with a bluer tinge to it. My stock ones are older though and probably getting toward the end of their useful life.
Dan just letting you know i found my steaga S2 lights they use D2R as well your 8000K ones fit in Steaga perfectly exact same setup as 34
S2 Steaga are Xennon Series one stock H4 or H1..
Edited by 53XYN
I used a stock loom for 9000k with no problem at all.. :cool:
i tried to take out my globes today and found out that there is a star shaped allen like key thing there.
WHERE THE HELL DO I GET ONE AND WHAT SIZE IS IT!!!???
Can any of you guys help me? As i'm getting a set off dan.
Cheers
Cheers
I just use a plier to bend the plastic stopper and turn anti-clockwise.. :D
I just use a plier to bend the plastic stopper and turn anti-clockwise.. :P
i don't want to be doing that.
knowing me, i'd break alot of things
You turn the cover with one hand, keeping pressure on it, flip the plastic tab with your finger slightly and it'll jump over the screw. When you do it up, just don't force it past when you screw the cover back.
Hey ,mate.
Just sent the payment through.
Please send me a set of 6000k globes.
Also which way do i turn the covers and how much do i turn them to take it off?
Is there no place that sell the star shaped allen keys? :laugh:
    • Have you flushed the initial fluid yet? It should look like a rainbow unicorn shat glitter into it. 2nd or 3rd fluid change is when you party.
    • all brand new unit from Tomei, fluid, bearings, etc. Tomei said they call it a 1.5 lsd because its 100 percent lock up under acceleration and 50 percent under deacceleration.  as I mentioned I used their fluid, install and their break-in procedure, (alot of figure 8's) but even when driving straight, or even slowly backing out of garage for first time, (at 2 mph) then driving to and from figure 8 parking lot, each tire in the rear would sporadically grab, skip, bounce, shutter and skip, shutter back a force I could feel causing clutch to slip then grab, at any speed. shaking entire car. I removed unit, since I put stock back in and all is fine, via process of elimination, its something with the lsd unit itself. I wasn't going to beat up the entire car more or change anything else for no reason as I had a feeling something in the lsd itself was wrong as everything was fine before this alone was installed and I rechecked over everything else after first time backing out I suspected an issue. I'll probably sadly already need new tires now just from trying to drive it 5 miles and performing the figure 8 break in. but if someone has any ideas I'm all ears
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
