Folks, have the following forsale
Project Mu SCR Pro 2 Piece Rotors - 800km old, in Original Boxes w/ paperwork
- For S14, S15, R32, Z32 TT
- 280mm x 30mm 5x114.3pcd
- Caliper on previous car (AP caliper) fouled on ali hat. Markings shown. Bugger all
- $900 Rotors, but for you my friend only $550ono
- Half the weight of 26x280mm factory rotors! Unbelievable price!
Pics: http://members.iinet.net.au/~ketterj/cefir...le/IMG_3090.JPG
http://members.iinet.net.au/~ketterj/cefir...le/IMG_3091.JPG
http://members.iinet.net.au/~ketterj/cefir...e/IMG_30921.JPG
http://members.iinet.net.au/~ketterj/cefir...le/IMG_3093.JPG
http://members.iinet.net.au/~ketterj/cefir...le/IMG_3094.JPG
http://members.iinet.net.au/~ketterj/cefir...le/IMG_3095.JPG
Trust 50mm Race BOV w/ 1m silicon hosing
- 50 mm inlet and outlet
- Plumback or atmo - HUUUUUGE
- Uses a valve, not piston - awesome adjustments possible
- $200 firm
http://members.iinet.net.au/~ketterj/cefir...le/IMG_3075.JPG
http://members.iinet.net.au/~ketterj/cefir...le/IMG_3076.jpg
http://members.iinet.net.au/~ketterj/cefir...le/IMG_3077.JPG
http://members.iinet.net.au/~ketterj/cefir...le/IMG_3079.JPG
Blitz BOV - Trumpet Exit
- 2 Bolt Nissan Flange included (bolt to SR intercooler, GTR, RB20/25 etc)
- Gasket
- $150
http://members.iinet.net.au/~ketterj/cefir...le/IMG_3078.JPG
Ali Steering Rack Spacer
- CNC machined, Used for 100km then got a defect for it
- Suggest you paint it black before installing!
- $40
http://members.iinet.net.au/~ketterj/cefir...le/IMG_3081.JPG
http://members.iinet.net.au/~ketterj/cefir...le/IMG_3082.JPG
Polyurethane/Nolothane Gearbox Mount
- Black
- $50
http://members.iinet.net.au/~ketterj/cefir...le/IMG_3080.JPG
RB20 / CA18 CoilPacks x6
- All working perfectly, Upgraded to Splitfires.
- $150
http://members.iinet.net.au/~ketterj/cefir...le/IMG_3088.JPG
Rb20 DET East Bear Cross Pipe
- Slight wear mark from rubbing on bonnet heat sheild.
- Comes with timing belt cover bracket
- $125
http://members.iinet.net.au/~ketterj/cefir...le/IMG_3085.JPG
http://members.iinet.net.au/~ketterj/cefir...le/IMG_3086.JPG
http://members.iinet.net.au/~ketterj/cefir...le/IMG_3087.JPG
4x S14 & 4x Z32 Wheels w/ various tyres - SOLD!!!!!
- Will separate
- Z wheels wider than S14
- $250 the lot or 150 a set
http://members.iinet.net.au/~ketterj/cefir...le/IMG_3096.JPG
Cefiro Lower Radiator Hose
- Factory item
- $10
http://members.iinet.net.au/~ketterj/cefir...le/IMG_3089.JPG
Cefiro Drivers Side Indicator Assembly
- No globes
- $75
http://members.iinet.net.au/~ketterj/cefir...le/IMG_3083.JPG
Cefiro Rear Bumper Bar, Side Panels and Front Fenders
- Rear Bumper in OK condition
- Fenders have had minor hits. Bolt up straight to chassis however
- $100 the lot
http://members.iinet.net.au/~ketterj/cefir...le/IMG_3073.JPG
Just Jap 3" Silicon Hose
- $10
http://members.iinet.net.au/~ketterj/cefir...le/IMG_3084.JPG
Jai
0422925440
  • 6 months later...
- $200 firm
- Gasket
- $150
- $40
- Black
- $50
- $150
- $125
- Will separate
- Factory item
- $10
- No globes
- $75
- $100 the lot
- $10
Jai
0422925440
hey there jai
how are ya
just wandering at all
if you would have a passenger side stock front indicator in good condition , the one next to the headlight
and also a pair of interior sun visors at all lying around i can grab off ya at the rite price
cash ready to go here
let me know asap if you can help me out man
wil speak to you soon
keep in touch
cheers anf
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
    • Yes it is ATF. I quote @Duncan "it takes a good synthentic auto trans fluid like Castrol Transmax Z" It's not a diff. It's a transfer case. Totally different thing. Yes, fluid will come out the sender hole. No you do not really need to drain it. Just pull the old, quickly poke the new, clean up and top up. But realistically, you should probably take the opportunity to change it anyway.
