well they are worn, no photos but they are nearly smooth, can see the tread however not much at all.....but these only can with a few mm of tread brand new and have the soft rubber down to the belts so there is still plenty...
i can try to arrange some pics but cant promise anything till the weekend....
https://www.sau.com.au/forums/topic/178274-delete/#findComment-3259772
The Nitto NT-555R Extreme Drag Radial Tire is an exciting addition to the specialty performance radial tire segment of the Nitto Tire Product Line. With the NT-555R Nitto engineers succeeded in designing a DOT approved, drag racing radial tire. Nitto Tire demanded a tire that would outperform all drag racing radial tires, provide impressive control and handling, and still deliver up to 15,000 miles of tread life of normal street-driving use. NT-555R's are manufactured with the original tread depth of 6/32nd's of an inch and are constructed with a specially formulated soft racing tread compound to provide maximum traction. However, this soft and flexible tread will wear much quicker than tread compounds formulated for regular passenger cars. The Nitto NT-555R is designed primarily for competition drag racing.
https://www.sau.com.au/forums/topic/178274-delete/#findComment-3259776
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
