Hey guys as the topic says just have a few things i want to get rid of.
Located in Melbs SE subs
cheers
R34 Stock Dump pipe, comes with O2 sensor and mounting bracket. $ 50
post-22171-1186133255_thumb.jpg post-22171-1186133374_thumb.jpg post-22171-1186133710_thumb.jpg
Stock R32 Gts-t rear wing, has Brake light still attatched $ 20
post-22171-1186134182_thumb.jpg post-22171-1186134926_thumb.jpg post-22171-1186135135_thumb.jpg
Edited by vsute
https://www.sau.com.au/forums/topic/179305-stock-r34-dump-pipe-and-o2-sensor/
THere is no elbow on this turbo, but i could take the one off the rb20, I would throw it in for the 250.
There isnt HEAPS of play but there is some there, But have to remember there is no oil in it.
YOur more than welcome to come round and check it out f you want
Thanks man.
I am checking out another one this weekend also, but may come check yours out first as you are closer.
Will give you a call on the weekend.
Thanks,
Abu
somthings come up lol yeh an attempt to buy a cheaper turbo lol thanks bro
Yep, something did come up.
My car failed the initial AQIS inspection and I was stuck with another invoice for an amount which I did not budget for, therefor I said I cannot afford to buy your turbo.
Hence why I am looking for something cheaper, locally.
That will save me paying postage on top of the cost of the item..
But like I said in my PM, if things change I will get back to you, but they haven't.
I am now playing with less of a budget meaning the cost of your turbo is out of my budget.
Sorry to go off topic vsute, this should have been said via PM.
Thanks,
Abu
Edited by abu
Thanks,
Abu
this guy is asking 250, u were gona buy mine for 250? simple maths tells me..... umm yeh u get wat im saying lol. its ok bro i dont mind relax lol
free bump good luck with the sale
The agreed price for your turbo was $280 delivered.. so simple maths tells me, thats already $30 greater than vsute's ASKING price. Therefor I am already at a $30 saving by not purchasing your turbo?..
And he is asking price $250 NEG.. meaning there is room for negotiation?
So how about you do the simple maths and work out where I am saving money?
If you have any other questions, feel free to send me a PM instead of trying to put me down in this thread.
Thanks,
Abu
Edited by abu
hey DjeMz,
The centre of the diff has been welded together, so its a full time lock diff. It was working fine when it was
pulled out of the car. So prob just put some new oil in it just to safe. and bolt it in.
Im selling it as I now have a Nismo 2 way
    • If they can dyno them, get them dyno'd, make sure they're not leaking, and if they look okay on the dyno and are performing relatively well, put them in the car.   If they're leaking oil etc, and you feel so inclined, open them up yourself and see what you can do to fix it. The main thing you're trying to do is replace the parts that perish, like seals. You're not attempting to change the valving. You might even be able to find somewhere that has the Tein parts/rebuild kit if you dig hard.
    • Can you also make sure the invoices on the box (And none exist in the boxes) are below our import duty limits... I jest, there's nothing I need to actually purchase and order in. (Unless you can find me a rear diff carrier, brand new, for stupidly cheap, that is for a Toyota Landcruiser, HZJ105R GXL, 2000 year model...)
    • Murphy strikes again! Nothing at all would have gone wrong if you had the tool kit in the car! You'd have just found the clamp loose the next time you went to touch it...
    • I have been being VERY quiet about what you're alluding to, as it is something that ticks me off... The number of cars from factory that run coil overs is HUGE! Most of them these days do... The other part that annoys me, is people saying "Well all the incabin adjustable suspension is illegal by blah blah blah"... If that's the case, then why can I buy a car brand new that can do it if, FULL STOP in cabin adjustable suspension is illegal...   Also, I could just chuck some aftermarket shocks in my car, throw the stock springs on, after my blue slip, dump my super low springs back in. Same shock and spring style setup... Hell, they could also be the same colour springs etc.     I'm voting, BlueSlipper didn't want to touch the above car for some reason. Whether it be some sort of bias against the car, the owner, them maybe having previously done dodgy shit and now they're being super careful in case they get slapped in the face by the Gumbyment again... Find a new blueslip place.   And can confirm as you had said, yes there are holy bibles of vehicle heights, and all sorts of other suspension stuff. Heck your run of the mill mechanic, and tyre shop has access to all of that stuff. It's how they do wheel alignments...
    • Funny story Heading to Sydney this morning on the HWY there was some slow traffic, so I gave it the beans and midway through my overtaking "power run" I lost all power It seems that I missed a hose clamp,  and the MAF and filter went WiFi To make this more problematic, the little tool kit that lives in the boot, is sitting in the sun room at Goulburn......LOL Luckily for me I found a bit of steel on the side of the road that could be used like a rusty and bent flat head screw driver to tighten it up enough that it got me into Sydney, it is now all tight like a tiger with the aid of a 8mm socket Note to self: Use my brain and double check stuff, and always keep that little tool kit in the car for when I have a brain fart
