It doesn't usually work very well. There are 2 options I forget, my mechanic set them both to 10%. It improved slightly, but not all that much. Changing your decelaration habits is the best way to stop it happening.
Edit: I think the setting is "Dec. Air" and has Lo and Hi settings or something.
Originally posted by Grim
Thanks but the safc is capable of correcting the problem...
As I already said, no it's not. You may see some improvement as I did, but also as with me and most other people it won't cure it. Set both settings to10% and see how you go.
Guest INASNT
grim u rice boy did u get a atmo venting bov??
remember we tried to set the dec air function with my blitz atmo and the s-afc?? if u dont remember, well it didnt work, it seemed like it worked but when u do a cold start the engine wont idle properly, its goes all crazy. In the end i had to turn the dec air thing off!!
Guest INASNT
I thought that was cos your BOV was mounted and sealed badly and was leaking air. plus i don't think we tried very hard to tune the dec-air feature....
nope i had my stock bov blocked and the blitz recoed with new springs.
The best thing i did was pissing the blitz bov off and going back to the stock bov!!
    • Hey guys Long time lurker, I daily a nm35 stagea 250t rs four and I've had it for almost 2 years (very reliable 👌). Issues or just looking for information ill always find myself here having a read, so thought id join.  3inch stainless intake, pod filter, AM performance turbo dump pipe, 3inch hotdog, 3 and half inch stainless to 3 and half inch AM performance blast pipes. Bc racing coilovers. 18inch rims Hdi intercooler and trans cooler soon.  Here's my car
    • thanks for the advice on the box... i was thinking the 6 speed was better for cruising on the highway but on closer inspection and comparison the Rb 5 speed box was not too different...  So the choice is going to be the RB25 box... if I can save up and find one at the right price
    • Thanks Matt, yes that's what i am aiming for. Just going to apply the right voltage and grounds to the dash connector. Hence my search for these pins... any chance you know if these pins are in the same spot as the ones on the S15 Dash connector? as mentioned above on page 8?
    • Yes, unfortunately that's the one. Signal was noisy to begin with; after driving once and looking back at the logs I saw pressure constantly swinging between 0-200psi, or staying at 0 randomly for a few seconds. There's a lot of good sensors that share the same look and feel, so don't presume they're all bad. I bought mine for 20$ off Amazon and I should have read the reviews prior, as it's clear they're junk.  I purchased a lowdollerr motorsports sensor.
    • wedding eh.....I seem to get to more funerals than weddings or christenings these days....
