looking for some workshops that do good work with boring, honing, crank linishing and general reco work for engine blocks.
If people could list places that they have used and have no problems recommending it would be great.
also prefer places that are inner sydney.
thanks
Edited by silver gts-t
https://www.sau.com.au/forums/topic/179510-engine-block-recos/
Only two places id use and recommend are Westend performance and duncan & foster.
Sam at westend is responciple for some of the best Drag engines around and many of the top fuelers as well, his done all of my machining for the last 9 years and ive never once had a problem with his work. His all to familiar with the Rb engine as well,
Duncan and foster we use for all out machining at work, they do good work and turn around is very reasonable time wise.
just to give people and idea and to get some feedback
called westend, spoke to sam and he seemed like a nice dude, nice to talk to..
acid clean $75
bore and hone $195
linish crank $49
bearings (king bearings)
$55
$75
forgot to ask about crack testing and balancing a crank >_<
ill call back when i got my pistons..
He is also correct.
Id probably be inclined to fit ARP bolts to your rods if you plan to use them, Close and hone the ones you have and have the little ends checked.
Sam has never let me down and like you say his prices are really good.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
    • Yeah, I would have said the same. It makes me suggest that there are other things wrong, such that the ECU is totally unhappy with the broken sensor. The only other thought here is that maybe it is shorted, which might cause a different issue to the typical "disconnected" sensor.
