hey, just thought i'd share. got the power fc installed and dyno tuned today by ed at autotech (him and peter are deadset champs btw!). car is COMPLETELY stock aside from a no name aftermarket cat back exhaust. was making around 160kw and now busts out 212kw! not too shabby for my first mod i have to say! drives like a bitch too, i'm pumped!
https://www.sau.com.au/forums/topic/180188-woohoo/
Awesome result Nick must be stocked.
But here is my little bit of input... not trying to be a tight arse but there is no way in hell you could make 212rwkw off just a PFC and a cat back exhaust. Either his dyno is reading even higher than normal or you have some more mods (i am sure it's the first :nyaanyaa:). Shauno's made slightly more than that and he had a heap more mods. The stock power output seems about right but 50kw from a tune with a stock turbo, stock cat, stock dump pipe, stock air filter (although this is not such an issue). What boost is it running ???
and he could have leaned it out even more thats about an 11.4 - 11.6 through out i think he did mine at 11.8 - 12.0
https://www.sau.com.au/forums/topic/180188-woohoo/#findComment-3279046
as far as i know the boost restrictor was already out. i felt the boost line off the solenoid and couldn't really feel anything inside it so...
212 does seem like a lot to me off a stocker, but if the original output is about right is there any reason to suspect the new output is off? boost i would imagine is sitting just under a bar. i don't have a boost controller yet and there's no reason for it to be running any higher than stock (minus the restrictor) boost. i dunno, hopefully its right, but if it is an exaggerated figure i don't really care that much cuz the car definitely feels much more responsive, smoother and much more powerful!
https://www.sau.com.au/forums/topic/180188-woohoo/#findComment-3279295
That power curve is smooth as a baby's butt... Very nice.
Im with Leigh on this one... There's no way that a stock RB25 can put 212kw to the wheels with only a Power FC exhaust and cooler... There must be something else that you dont know about that was done to it in Japan by a previous owner.
My RB25 put down 230kw at the wheels on the same dyno and Ive got a Power FC, 3" exhaust, Front mount cooler, Splitfire ignition coils, 550cc injectors + 040 Fuel pump and a GT30 turbo (only running 12psi at the moment).
You might have a high flowed turbo that you dont know about, because peak boost looks like its coming on a bit late judging by that readout and 1 bar is allot for the standard turbo, they usually let go at about that sort of pressure.
High flow turbo's usually dont look any different to stock from the outside.
Anyway, nice result and a very nice power curve, lots of mid range torque, it must feel really responsive to drive.
Edited by Bullet32
https://www.sau.com.au/forums/topic/180188-woohoo/#findComment-3279482
fark me i appologise i thought it was an R33 GTS-T same as Mick. I figure if it's on Autotech then it has to be RWD or FWD damn r32's and there fuses hehe
My appologies nick as the r32 gtrs should be able to put that sort of power out. Still 50KW is an awesome improvement for just a pfc... i feel like a n00b for jumping on the defence :)
https://www.sau.com.au/forums/topic/180188-woohoo/#findComment-3279972
well it definitely wasn't the falcon! thats cool guys, appreciate the input nonetheless. question, with the boost restrictor out there isn't any chance that the turbos will go about 1 bar is there? as far as i'm aware they hold at about 14 but i don't have a boost controller so i can't say for sure. in the mean time i'm holding off giving them complete death for fear of shattering one.
https://www.sau.com.au/forums/topic/180188-woohoo/#findComment-3280092
I dont know if you'll get big boost spikes from the standard turbo's they're pretty reliable... But if you want to know exactly what psi youre getting under load Pete should be able to tell you. He'll put an inline sensor in one of your boost hoses on the plenum side that reads the pressure level while the car is on the dyno and gives a very accurate reading of your boost level.
*** Dont trust your boost guage ***
https://www.sau.com.au/forums/topic/180188-woohoo/#findComment-3280179
9.5 ish stock, 15 without the restrictor. don't know if Pete's dyno is optimistic or not, but 212 rwkw from a GTR with those mods seems fine to me. a VDO boost gauge (good enough for the Gamballa Avalanche, good enough for me) costs bugger all and no more guessing. got mine from Premier Instruments in Dickson.
Edited by Scooby
https://www.sau.com.au/forums/topic/180188-woohoo/#findComment-3280833
Good result,
Is pretty much normal for something like that,
I think my first gtr with the same mods and cam gears made about 230kw so is pretty reasonable.
I do agree with leech though, the afrs are a little rich still and should be at 12.0 to 1 to get the best result.
12.4 12.5 will get you your best power but leaves it a bit on the edge for street driving.
Ed does like to leave them on the safe side though.
https://www.sau.com.au/forums/topic/180188-woohoo/#findComment-3281060
That's a pretty darn good result, i had my car tuned there by Ed as well, really happy with the way it drives now, totally new car.
Someone told me Ed left Integra and he's at Autotech now?? That true? I haven't had my car serviced since that little NSW licence suspension....
https://www.sau.com.au/forums/topic/180188-woohoo/#findComment-3285503
basically just wanted a solid safe tune. didn't have much of a hand in it as i was at work while it was going on, and as people have said, could've still leaned out the afr's a bit and will most likely go back for that at some stage but yeah - the car's definitely not maxed out or anything.
https://www.sau.com.au/forums/topic/180188-woohoo/#findComment-3286070
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
