I'd like to hear from people with experience in using flat tops or even dished pistons in a RB30 with a 26 head.
Flat tops usually give a C/R of 8.2-8.3, dished can get you down to the low 7's
I want to hear from guys who have made big power (as in 600,800, 1000hp+) when using flat tops or dished pistons, only in a RB30 and only when using a 26 head.
If you can answer the following:
1) what shape did you use, flat tops(8.2-8.3:1), very slight dish(high 7's to 8.2:1) or larger dish (lower than high 7's:1)
2) what fuel did you use
3) what cams (if you want to say) and head work, none, mild, extensive.
4) what turbo
5) how much power did you make, at what boost, with what torque, rpm etc
6) without NOS, hp?
6) with NOS hp?
This may seem a strange request from me but I have a situation that needs independent outside input.
PLEASE, only post if you can back it up with dyno printouts, video proof etc, not my mate said this and that please.
Feel free to add dyno printouts here, e-mail me dyno printouts or PM me if you'd rather others didn't see your data.
Thanks Rob
Edited by R.I.P.S NZ
4) what turbo
6) without NOS, hp?
6) with NOS hp?
Thanks Rob
Why do you ask this Rob , as i have made 580 atw 0n 19lb with 98 Ultimate, Ross flat tops- i have dyno sheets. I am interested why you ask this as?
Thanks for your reply, its a long story but I need input from as many people as possible who have made good power with flat tops or even dished pistons in a 26/30, PLEASE put up your dyno printout and I'll explain everything once I have a few more replies on here.
Nothing shady going on I assure you
Thanks Rob
    • I guess one thing that might be wrong is the manifold pressure.  It is a constant -5.9 and never moves even under 100% throttle and load.  I would expect it to atleast go to 0 correct?  It's doing this with the OEM MAP as well as the ECU vacuum sensor. When trying to tune the base map under load the crosshairs only climb vertically with RPM, but always in the -5.9 column.
    • AHHHH gotchaa, I'll do that once I am home again. I tried doing the harness with the multimeter but it seems the car needed a jump, there was no power when it was in the "ON" position. Not sure if I should use car battery jump starter or if its because the stuff that has been disconnect the car just does send power.
    • As far as I can tell I have everything properly set in the Haltech software for engine size, injector data, all sensors seem to be reporting proper numbers.  If I change any injector details it doesnt run right.    Changing the base map is having the biggest change in response, im not sure how people are saying it doesnt really matter.  I'm guessing under normal conditions the ECU is able to self adjust and keep everything smooth.   Right now my best performance is happening by lowering the base map just enough to where the ECU us doing short term cut of about 45% to reach the target Lambda of 14.7.  That way when I start putting load on it still has high enough fuel map to not be so lean.  After 2500 rpm I raised the base map to what would be really rich at no load, but still helps with the lean spots on load.  I figure I don't have much reason to be above 2500rpm with no load.  When watching other videos it seems their target is reached much faster than mine.  Mine takes forever to adjust and reach the target. My next few days will be spent making sure timing is good, it was running fine before doing the ECU and DBW swap, but want to verify.  I'll also probably swap in the new injectors I bought as well as a walbro 255 pump.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
