Hi,
My R33 was imported to AUS in May 07, and at the time it had 95000 on the clock(i am the first owner), which means that i would need to do the timing belt and the water pump soon, but i noticed JAP sticker, its on the cover of the timing belt saying 91365 KM, and somthing else in jap which i am trying to figure out ... i am thinking that they replaced it before the car got to AUS, other belts seem new, water pump has a slightly different colour, and the screws around and on it seem to be worked on,
I am not shore, should i risk or not??? if it was done no point doing it again and plust it cost 6 7 800 bucks ...
I will take the cover of to check the belt for cracks and see (it should still look new)
But if the sticker confirms that it was done ... i will be the happiest :P
Can anyone translate it to me, plz
Thanks
https://www.sau.com.au/forums/topic/182321-jap-sticker/
Your sticker says...
Timing belt change
Date: 24 November 2006
Odo: 93165
Just a sticker though, anyone could have put it there! Still if the belt looks in new condition you can be fairly confident it has been done.
Hi,
Thanks for that pal, i will still take the cover off to have a look.
I dont think that anyone would put somthing like ther just to f...ck someone up if it wasnt done, at least it wouldnt do it, but u know ther r all sorts of ppl out there ... but again noone can benifit from it
Thanks a lot again.
https://www.sau.com.au/forums/topic/182321-jap-sticker/#findComment-3309738
hmmmmmmmmmm
g i h8 dodgey jobs n ppl ... do it properly or dont f.. do it
loosers
Based on things that i have seen on the car i am positive, that its been done, but just 4 my own peace of minde, i will take the cover off to check for craks ... or if it look new
https://www.sau.com.au/forums/topic/182321-jap-sticker/#findComment-3311901
HELLRAISER - You said that you think it will cost 6 - 7- $800 to do your timing belt???
Youre getting ripped off if you've been quoted that much!
Yeah pal, i know, thats for d water pump and a belt( to be more specific $890), quoted to me by a shop thats advertasing on this webpage, i know that they have good reputation but ... its way too much
https://www.sau.com.au/forums/topic/182321-jap-sticker/#findComment-3314375
    • Reading through the engine service manual their advice is do a cylinder balance test. Unplug one injector at a time and see if the idle drops a consistent RPM. You can also do this using a Consult cable which is easier. They also call for unplugging the power transistor, then with the engine off and the fuel rail unhooked from the manifold verifying that you have good fuel flow (even injection, no dripping/leaks, etc) when you twist the CAS by hand. Also verify the spark by pulling the spark plugs and allowing the plugs to ground and turning the CAS by hand. I would also start doing the sensor checks and idle valve checks in service manual. Make sure the MAF tests reasonably, the intake air regulator is sane, etc. You may have to get new spark plugs.
    • This sounds very old of me, however since buying the Tiguan shit box, my view on shit boxes have changed.
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
    • This coupled with 6-9 speed autos with ridiculously short gearing is why these modern shitbox cars always seem so fast off the line. If it wasn't for those things, Raptors would not seem fast. The problem we have is there is a driveability gap between a more gentle take off and a wheelspinning sideways launch. The difference between ankle flex required to achieve one and ankle flex required to achieve the other is about 0.5°.
    • Yeah I think I'm also with the opposite here. It's 'hard to keep up with traffic' because in the real world I'm accelerating with 15% throttle and they are pinning it. It feels like I'm being an overt dickhead at anything above 15% throttle, so the car sounds like I'm being an overt dickhead to keep up with/get ahead of traffic when I'm really just trying to drive with traffic. There would be no issue 'keeping up with traffic' if we used the same level of throttle input/aggression to drive around. People really do just drive around with their foot nearly pinned in econoboxes.
