1989 gts-4 r32
mods/features:
-black
-manual
-4WD (but can safely be made RWD with the removal of a fuse with no adverse affects)
-ABS
-HICAS 4 wheel steering
-108***kms
-FMIC
-pod filter
-turbo timer
-BOV
-turbotech boost controller
-3in exhaust
-new clutch in the last year
-timing belt replaced at 100000km
-always used motul oil which is changed every 10000km
-18" rims
-power windows/mirrors
-remote keyless entry
-mp3 cd player, amp and sub
-6x9's on the back shelf
the front bar is cracked and for the car to be in good exterior condition you might want to put a new kit on it.
-rego expires in november
-I have owned the car for the past year and it has been mainly used for highway driving to and from uni.
-my reason for selling is that i took out a loan and want to pay the money back now so i can quit work and concentrate on uni
Price is $9000 but all offers considered
Located in the Sutherland Shire (South Sydney)
Call me on 0421763988 or PM me for any more enquiries
Edited by Kribside
https://www.sau.com.au/forums/topic/182600-sold/
  • 3 weeks later...
  • 4 weeks later...
