24 August 2007
As of 2010, Jaguar's V8 engine will feature in the Ford Falcons. Paul Gover and Neil McDonald
August 24, 2007 12:00am
A JAGUAR V8 will power the next-generation Ford Falcon.
The hi-tech 5.0-litre V8 will be introduced in 2010 -- a year that is shaping as a boomer for Ford Australia, thanks to the first facelift of the Orion Falcon, the switch to V6 engines in Ford's family fighter, and the probable introduction of the next-generation Territory.
There is a good chance 2010 will also bring the first diesel engine to the Falcon and Territory, in the form of a 2.7-litre powerplant already in use in Europe.
The good news on the V8 front comes as Ford Australia confirms plans to axe its existing 5.4-litre V8, which was standard in the G8, Fairlane and LTD and optional in a range of other Fords including the Falcon ute. The Jaguar V8 is a new all-alloy design developed for the forthcoming XF, a make-or-break model for the British luxury brand.
The XF and its new V8 will be seen for the first time at the Frankfurt Motor Show next month, though Jaguar showed off a C-XF at the Detroit Motor Show earlier in the year.
The new Jaguar V8 will be available in naturally aspirated form and with a supercharger. The basic bottom line is 375kW.
It will be the hero engine for the XR8 Falcon and will be used in the feisty fliers from Ford Performance Vehicles. The move to the Jaguar V8 is part of a shift prompted by the end of production of the existing 5.4-litre engine.
Ford Australia imports the engine from the Essex plant in Ontario, Canada, which has been steadily phasing out the engine.
Locally, the engine was known as the Barra 220 or Barra 230, depending on the application. The number reflects its kilowatt output.
Still, Ford will continue with the partly locally assembled four-valve twin-overhead camshaft version of the same engine in its Falcon XR8 and FPV models.
The three-valve V8 was optional on the base-model BA Falcon from 2002, replacing the ancient 5.0-litre Windsor pushrod V8.
Ford's Broadmeadows factory has had little use for the engine, according to Ford Australia president Tom Gorman.
"We were down to about 10 a month and it's not a major impact on our business," Gorman says. "They've actually ceased production in the US and we're ceasing production on our long-wheelbase cars."
Gorman says Ford has enough V8s stockpiled to meet demand in the long-wheelbase cars until production of the Fairlane ends in a few months.
https://www.sau.com.au/forums/topic/182831-jag-v8-to-power-fordfpv/
Interesting read.. sounds like they will make a power house Engine..
Is this Jaguars Last ditch effort to help them get a profit in the coming years?? last i heard they were almost bought out by a russian Company called GAZ, and they are in debt up to their armpits.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
