GTR injectors will be fine for the 2530, but injector size doesn't really depend on the type of turbo, more on the power your making and the boost your running, also what engine your running it on.
Best to post some more specs up as well as a power estimate your hopinh for so you can get a more detailed answer.
GTR injectors a fairly big and support a fair bit of power, but my understanding of "fair power" and your understanding could be a few hundred KW out.
Not sure on the dump pipe, again would depend on the car.
Edited by abu
Car is S13 , RB20 , forward facing int. fmc. HKS2530, PFC for RB26. Looking for what ever it can make maybe 300rwh, not going crazy, trying to keep it a driver. I know from reading the 555 would be over kill.so I thought I would ask. Thanks
Stock injectors usually get high into there cycle up around 210 - 220rwkw, making them more likely of failure so yep, best to upgrade for sure.
GTR injectors will be fine for 300rwhp.
R32 GTR injectors with a resistor pack are a good upgrade for RB20.
Edited by abu
Thank you, that's the answer I was looking for. I also do have the resistor pack,saw the write up for installing the pak. 180boy
Awesome!
Good luck with it all man, post up your results when you get it up and running.
Abu
Edited by abu
you'll find your factory injectors will be good up to 230rwkw, and the HKS2530 will run outof puff at about there too.
220rwkw would be fine with factory injectors.
I've even heard of people running 240rwkw with factory injectors maxed. Then if you want to take a risk, get a FPR?
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
