GTR injectors will be fine for the 2530, but injector size doesn't really depend on the type of turbo, more on the power your making and the boost your running, also what engine your running it on.
Best to post some more specs up as well as a power estimate your hopinh for so you can get a more detailed answer.
GTR injectors a fairly big and support a fair bit of power, but my understanding of "fair power" and your understanding could be a few hundred KW out.
Not sure on the dump pipe, again would depend on the car.
Edited by abu
Car is S13 , RB20 , forward facing int. fmc. HKS2530, PFC for RB26. Looking for what ever it can make maybe 300rwh, not going crazy, trying to keep it a driver. I know from reading the 555 would be over kill.so I thought I would ask. Thanks
Stock injectors usually get high into there cycle up around 210 - 220rwkw, making them more likely of failure so yep, best to upgrade for sure.
GTR injectors will be fine for 300rwhp.
R32 GTR injectors with a resistor pack are a good upgrade for RB20.
Edited by abu
Thank you, that's the answer I was looking for. I also do have the resistor pack,saw the write up for installing the pak. 180boy
Awesome!
Good luck with it all man, post up your results when you get it up and running.
Abu
Edited by abu
you'll find your factory injectors will be good up to 230rwkw, and the HKS2530 will run outof puff at about there too.
220rwkw would be fine with factory injectors.
I've even heard of people running 240rwkw with factory injectors maxed. Then if you want to take a risk, get a FPR?
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
